Pinion yoke
Old Sep 14, 2006 | 04:58 AM
32chevy vett's Avatar
32chevy vett
Default Pinion yoke
I broke a bolt in my pinion yoke and had to remove the yoke,can i replace it and torque it down. If so what is the torque. will this change my clearance with the ring gear.
Old Sep 14, 2006 | 06:04 AM
toptechx6's Avatar
toptechx6
Both 36 and 44 rear axles use shims to set pinion depth and bearing preload so you should have no problems if you torque to specs. 200 ft. lbs. for the 36 or 250 ft. lbs for the 44, hope that helps.
