Clutch Bleeding
Old Sep 14, 2006 | 03:40 PM
Great White North's Avatar
Great White North
Default Clutch Bleeding
I have had poor luck getting all the air from the system.I used mighty vac, manual etc.So someone on the forum suggested a Phoenix bleeder.It arrived yesterday.I raised the car high enough to get under,this also put the slave at a flat angle.I emptied the master and held an adapter on the slave,two pumps,tighten the bleeder.I cant believe it,instant clutch!!! It was so easy with that tool.It took longer to lift the car than to bleed it.So thanks to who ever said to get one!!!
Old Sep 14, 2006 | 04:40 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Did you get the V-12?
http://www.brakebleeder.com/cart/ind...=index&cPath=1
How does it work...reverse bleeding??
Larry
code5coupe
Old Sep 14, 2006 | 04:59 PM
Great White North
Larry
code5coupe
Yes,you force the fluid up from the bottom.I got the V12.Comes with a pile of fittings.Unbelievable how fast!!!
Old Sep 14, 2006 | 08:06 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Does this mean you have a vette you can drive
Old Sep 14, 2006 | 08:35 PM
Great White North
It was just great last night!!!
To Clutch Bleeding
