SPARK PLUG TRICK!!!!!!!!!
Old Sep 12, 2001 | 06:29 PM
KNCRSR5R's Avatar
KNCRSR5R
Default SPARK PLUG TRICK!!!!!!!!!
I read somewhere recently that you could trim back the plug and get the same performance that the +4's deliver, and that this is all that BOSCH did to their plugs. Is this true?
IF SO, how do you perform the mod to the plug? How much to trim? I heard it was an old trick so I would imagine alot of guys know!
Any pros or cons I need to know about?
:cheers:
Old Sep 12, 2001 | 07:02 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: SPARK PLUG TRICK!!!!!!!!! (KNCRSR5R)
I just cut the ground electrode off so that it just reaches the near edge of the center electrode. Then I take a fine file to smooth any sharp edges or burs.
I've seen this hint in TPIS "Insider Hints" and in Dave Emanuel's book on SBCs.
On the plus side the cleaner burn brought me 10HP more (consistently 1mph faster through the traps), better fuel economy and lower emissions (note that I have other ignition mods too).
On the minus side the plugs may not last as long as if unmodified.
[Modified by 65Z01, 5:03 PM 9/12/2001]
Old Sep 12, 2001 | 07:07 PM
White Lightning's Avatar
White Lightning
Before trying this trick on my Vette, I tested it on my 1990 Toyota Corolla. Seems to work fine, with about 10% better MPG: from 28 to 31. No noticeable increase in HP, but Corolla's aren't powerhouses to begin with so it would be hard to tell. Am planning on doing this mod to the Vette now that I've tested it.
-WL
Old Sep 12, 2001 | 09:26 PM
lowflyer's Avatar
lowflyer
Cruise-In I Veteran
Default Re: SPARK PLUG TRICK!!!!!!!!! (White Lightning)
I heard about this awhile ago and still am not convinced that it actually INCREASES power. All the mod does is that it gives the current a different path to ground, not a better one, or a closer one, just a different one. Am I wrong? If the spark is not increased in intensity, size or duration, how does it increase combustion efficiency? It would be great if something this simple would increase hp. Could someone clearify this for me? Thanks.
Old Sep 12, 2001 | 09:37 PM
65Z01's Avatar
65Z01
Default Re: SPARK PLUG TRICK!!!!!!!!! (lowflyer)
"...There's no question that unshrouding the ground electrode increases horsepower..." Dave Emanuel on P.124 in the Electrode Shapes section of his book on SBC performance. The key word here is "unshrouding".
Old Sep 12, 2001 | 09:38 PM
Romeo Barrera's Avatar
Romeo Barrera
It exposes the spark to the incoming air/fuel mixture. The electrode normally shrouds the spark somewhat and the modification gives it alot more exposure, resulting in more efficient combustion.
[Modified by Romeo Barrera, 8:39 PM 9/12/2001]
Old Sep 12, 2001 | 09:39 PM
Romeo Barrera
Default Re: SPARK PLUG TRICK!!!!!!!!! (Romeo Barrera)
Beat me again :p:
Old Sep 12, 2001 | 09:47 PM
lowflyer's Avatar
lowflyer
Cruise-In I Veteran
So its not the cutting of the electrode, but the indexing of the plug? That trick I know works...
Old Sep 12, 2001 | 09:54 PM
Chris@SD's Avatar
Chris@SD
Both unshrouding the electrode as well as indexing the plugs is a good thing. You are not going to feel the power increase. We did it on a 550 HP small block and picked up like 4 HP on an engine dyno. You would have to have a pretty bad case of hemoroids for the butt-o-meter to pick that up. ;)
Old Sep 13, 2001 | 12:57 AM
KNCRSR5R's Avatar
KNCRSR5R
Default Re: SPARK PLUG TRICK!!!!!!!!! (2FST4U)
Thansk for the replies and all the clarification! What is the deal with the plug extension?? I understand everything else!
Thanks! :cheers:
Old Sep 13, 2001 | 10:27 AM
lcvette's Avatar
lcvette
does someone think they could post a before after closeup picture fo the plugs so us do it yourselfers don't start snipping the entire electrodes off our plugs in search for an extra pony or two? :smash: :smash: :smash: thanks guys, i will do anyhting i can for that extra advantage!!
chris
Old Sep 13, 2001 | 03:02 PM
Raysur's Avatar
Raysur
Default Re: SPARK PLUG TRICK!!!!!!!!! (lcvette)
lcvette,
http://performanceunlimited.com/illu...parkplugs.html
How do you index a plug for the best performance?
To SPARK PLUG TRICK!!!!!!!!!
