easy ? for someone
Old Sep 15, 2006 | 03:40 AM
Bubba91's Avatar
Bubba91
Default easy ? for someone
My vette is a DD, but if I let it sit and don't drive it for one day. Then, the next time I drive it, it runs pretty rough for about a mile, then it clears up and is fine.
Leaky injector(s)? I ohmed them hot and cold and they tested fine.
Clogged cat(s)?
Old Sep 15, 2006 | 03:53 AM
Demonic85's Avatar
Demonic85
Is it burning oil? A clogged cat would make it run like crap all the time. IDK about the injectors.
Old Sep 15, 2006 | 03:57 AM
toptechx6's Avatar
toptechx6
Leaking injectors is still a possibility, checking them with an ohmmeter just checks the electrical coil, they could still be bad mechanically. A plugged cat would not normally clear up after running a few minutes. Some scan data might help, could also be a sensor reading incorrectly. Good luck.
Old Sep 15, 2006 | 09:21 AM
pcolt94's Avatar
pcolt94
When you ‘ohm it out’, you only check the resistance of the coil in the solenoid. But the actual valve where it seals could still very well leak. That’s the mechanical part, separate from the electrical portion. Measuring the resistance is not a direct test of the valve.
So good measurements means maybe good, and bad measurements means solenoid portion might be weak, valve might be good but injector should be changed.
Old Sep 15, 2006 | 09:41 AM
rick lambert's Avatar
rick lambert
Time to check the fuel pressure.
Old Sep 16, 2006 | 12:16 AM
Bubba91's Avatar
Bubba91
I see, thanks
I have to get my fuel pressure gauge fixed. Dang it, I keep meaning to do that. I will check that out thanks.
Old Sep 16, 2006 | 06:39 AM
RRT vette's Avatar
RRT vette
Get the fuel pressure guage and attach it to the schrader valve. Turn the key to "on" and observe what pressure you have. Watch it for a while and see how long it takes to drop and what number it drops to. You can also pinch off the fuel return line after the system is primed to see if it drops slower or faster.
https://www.corvetteforum.com/techti...=278&TopicID=2
To easy ? for someone
