After you bypass the the coolant from the throttle body, is it worth installing a cold air intake? Since the air going into the engine is not heated anymore.
The air going to the airbox is preheated, since most of it is what comes through the radiator and curves around into the box. Installing a true cold air intake will help compared to stock.
Intake air preheating at the TB is a different issue.
Well mostly I agree.....On my 96 GM did a pretty good job of blocking hot air from the engine compartment from going into the intake.....but then again you are correct that at least some of the intake air comes from the engine compartment.....
GM did make changes during the C4 era.....to be honest I don't really know how a 96 compares to an 86 for example.....
I am sure my SLP triple snorkel allows more hot air into the intake than stock since the baffles installed for the OEM system are no longer effective.....and it is supposed to be a cold air intake......my IAT monitoring says otherwise..
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Only a true cold air system that brings in air externally will be of enough benefit to be worth the cost or bother. And only then at speeds in excess of what you should be doing on the highway.
I dont think you understand, the C4 doesnt primarily breathe through that little slit between the shroud and nose or the hood and bumper. The air flows in two 'funnel' shaped paths on either side of the intake tract, that comes through the radiator dodging the MAF or snorkel intake and wrapping around to the airbox.
And they closed those gaps smaller between the shroud and the nose on later years.
Always a true cold air intake will help your performance only at 40mph and up, its about a 10HP increase depending what other mods are done to the air intake system. But at all times the reason the coolant is passing throught he throttle body is to keep the throttle plates from freezing and sticking open. If you feel you will never be affected by this keep going. The best systen to use is the won that you instaal in the front bumper where the plate goes. any other system still pulles in warm air. We tried a comparison on a 91 lt1 and found that systems that breathe from any where under the hood or around anything warm like the rad, you dont see much performance, but the won installed in the bumper reduces your air intake temp by 10 deg.
There are also alot of variables. For instance, Doing 90 MPH in 10*F is going to make more power than going the same speed in 90*F. We know that the colder the air, the more tightly packed the molecules. Makes for a meaner charge. As long as your throttle body doesn't freeze. the best cold air intake are the ones in front of the radiator. Unless of course your using a giant air scoop on your hood. Then of course you can't see where your going. It is kind of a hot topic on the forum...
I'm running an SLP on my 88, and haven't had a chance to test it yet. However, I believe I will take the plastic air cleaner cover, and scoop to an aluminum fabricator, an see if he can copy it in aluminum. That plastic sucks. Then, I would add a bolt on funnel system to scoop more air. Gotta be carefull in this area, as the radiator needs it share of air also. Not much room to work in this area on Corvette's. That is just the way it is. I guess if you don't need to put a plate on the front of your car, the bumper scoop makes alot of sense, but I have NO experience with this unit...
True, I don't really understand how the C4 gets its intake air....I keep trying to really figure out so I can make mine better..
Look at this photo (Not mine,,,,I pirated it)
See the rubber wiper on the hood.....there are also some foam pieces mounted on the radiator bracing not so visible in this photo......notice also the triangle shaped pieces mounted on the hood on both sides.......they block the direct entry of air that has been heated thru the radiator......the air coming up from the sides is a mixture involving some heated air, but certainly also a significant amount of cooler air coming from under the car....
I cut out the front license plate and installed the cold ram air package. no matter what anyone else says, my gas mileage improved but can't swear that the SOP performance is better.
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
You're confusing cold air intake and ram air intake. Cold air intake performance is independent of vehicle speed.
Where did you get that TB plate!? I need one of those!!!
It is part of my Barry Grant "Nitrous Works" TPI kit. And yes comp, it is a wet kit hence the second solenoid tapped into the fuel schrader valve for fuel. The single "third" solenoid by itself before the nitrous solenoid is my purge.
I dont know if they sell the plate alone without the kit but you can go here and inquire.
