anyone out there change both fuel lines over to braided line from the filter to fuel rail?if so what was needed lookin for parts. any help is appreciated.
I used steel brade hose and 3 hose clamps on each line and faired the lines.
I cut it after the filter and flaired the end.
To find a fitting for the fuel filter or the connector in line you will have to look around.
The lines are pipe thread and metric into the fuel rail.
If you want to make it look pretty at the fuel rails instead of barb fittings and hose clamps there is alway these to take a AN-6 fitting
eBay item #250014023809
Have seen them listed on other catalogs ,
Earls / Russell maybe
Check your rail fittings first , some have 2 the same size and some intakes (later ???) have 1 larger than the other.
Just did this with my 85, for the same reasons as you. Used an6 fittings, and braided hose. Only difference is, I routed mine to enter and return from the rear of the fuel rail, instead of the front. Much cleaner install...
