tuned port
Old Sep 17, 2006 | 12:29 PM
wjmac40's Avatar
wjmac40
Default tuned port
What is the sensor on the passager side front of engine attached to the tuned port?Has three prongs.My vette is an 89 ,but I believe the engine has been changed out. Bought it a couple months ago and still learning. Could this be a MAP sensor?
Old Sep 22, 2006 | 12:21 PM
RRT vette's Avatar
RRT vette
No the 89 doesn't have a MAP sensor, yours gets it's reading from the MAF. 91-93 vettes get the readings from the MAP and they don't have a MAF. From the description it sounds like the TPS (throttle postion sensor). It is mounted on the passenger (right) side of the throttle body and has three wires that pin into the TPS connector. It is used to send voltage readings to the ECM for postion of the throttle plates. As the plates (butterflys) open the voltage increases.
