Fuel Pump Pulsator
Old Sep 21, 2006 | 05:35 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default Fuel Pump Pulsator
I was reading about how these can stop fuel pressure loss and vibration, but how does it work?
Also, does my car have one?
I looked in the Helms index and did not see it listed.
Old Sep 21, 2006 | 05:44 PM
RRT vette's Avatar
RRT vette
Yes, your 93 has one. It reduces the fuel pressure variations that occur as the fuel injectors open and close, and to reduce operating noise.
Old Sep 22, 2006 | 12:53 AM
raisinbran's Avatar
raisinbran
I replaced mine when my fuel pressure would drop off pretty quickly after shutting the engine down. Held the pressure for hours with the new one!
Old Sep 22, 2006 | 08:45 AM
RRT vette's Avatar
RRT vette
these is one of the item the FSM states will cause a decrease in fuel pressure after the pump turns off.
Old Sep 22, 2006 | 09:34 AM
kopbet89c4's Avatar
kopbet89c4
I took mine off and used a rubber hose in place of it after changing my fuel pump. Without the pulsator, you can hear a lot more ticking from the injectors.
Old Sep 22, 2006 | 09:52 AM
mikey whipreck's Avatar
mikey whipreck
Isn't that hard on the injectors (water-hammer effect)?
Old Sep 22, 2006 | 10:01 AM
Randy93's Avatar
Randy93
St. Jude Donor '06
Is it inside the tank?
Old Sep 22, 2006 | 10:08 AM
kopbet89c4's Avatar
kopbet89c4
Probably would be more effective in knocking out deposits or impurities which sometimes cause injectors to fail. I like hearing my injectors knowing they are working all right.
Old Sep 22, 2006 | 10:10 AM
kopbet89c4's Avatar
kopbet89c4
Yes, its in between the fuel pump nose and the metal tube.
To Fuel Pump Pulsator
