Hatch Weatherstripping
Old Sep 22, 2006 | 06:03 PM
Brimis's Avatar
Brimis
Default Hatch Weatherstripping
It's time to insall the hatch weatherstrip, does it just lay in the hatch or do you secure it with an adhesive?
Old Sep 22, 2006 | 06:12 PM
RRT vette's Avatar
RRT vette
See if THIS helps.
Old Sep 22, 2006 | 06:24 PM
Brimis's Avatar
Brimis
Seems like some use glue and some do not.
Old Sep 22, 2006 | 06:28 PM
RRT vette's Avatar
RRT vette
I used 3M weatherstripping adhesive because mine would not stay down and when I let the back glass up the ws would come with it. It went pretty smooth except for removing the excess adhesive. I used a hairdryer and some stuff called "Prep all" and a rag. You have to get it hot so it will release easier other wise you end up with sorer (sp?) fingers and more time spent. The more careful you are the better. You can try without adhesive to start with.
Old Sep 23, 2006 | 12:07 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
No glue on mine except for that yellow gunk that was already there.
Old Sep 23, 2006 | 06:32 AM
Goldcylon's Avatar
Goldcylon
Default re:Loose or glued rear weatherstripping
I was wondering about this as mine is loose as well. I guess their are two school of thoughts and whatever works?
Old Sep 24, 2006 | 12:00 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Saw a hot rod segment on corvette weatherstrip on 88, and they only suggested putting some in the corners by the pillars to hold it in the V-grove, when i did mine, thats the only place i added the "black glue" -
some other tricks (which definately helped were) - leave indoors to room temp, - when installing use hair dryer to heat as you move along, - glue the corners and tape in place, - install and keep hatch closed for 24hrs to form.
Have not had any leak issues or fit .... so gotta figure it worked.
To Hatch Weatherstripping
