installing 1.6 RR's, Reprogram Chip?
Old Sep 23, 2006 | 08:23 PM
CALI C4er's Avatar
CALI C4er
Default installing 1.6 RR's, Reprogram Chip?
I plan to install Comp Pro Magnum 1.6 in my 88. I have a FASTCHIP. I emailed FASTCHIP and they said they would reprogram my chip for $150.00. Do you think it's has to be done over for this mod?
Old Sep 23, 2006 | 08:30 PM
ultraviolet70's Avatar
ultraviolet70
If that's the only change being or been made since the chip was burned for your application, can't see the slight change in lift necessitating a recal.
Old Sep 23, 2006 | 08:48 PM
Zix's Avatar
Zix
No need to reprogram for a 1.5 to 1.6 rocker change. I didn't reprogram when I went from 1.6 to 1.7 when I had my heads/cam setup. I have a lot of datalogging utilities and I saw no problems, everything was running just as good as with the 1.6 rockers.
Old Sep 23, 2006 | 11:50 PM
vader86's Avatar
vader86
No chip should be required for just this mod.
Old Sep 24, 2006 | 12:16 AM
VenkmanP's Avatar
VenkmanP
"Has to"? no.
"Want to"? maybe.
I don't know about L98, but a stock LT1 can get 15-20 rwhp from tuning, so if I added mods I'd definitely consider a tune.
I guess for me it would depend on whether this was the end-goal or not. If that's all the mods you're going to do, then get it tuned. If it's just a first step, then either wait, or get the equipment to tune it yourself.
To installing 1.6 RR's, Reprogram Chip?
