Worn distibutor question..
your rough idle is very likely due to worn valve seats AND guides....oem valve guides have two seals rather than one (which would suffice for oil control) to reduce cat contamination (feds say the factory MUST replace any emission component which fails before 50k.
http://forums.corvetteforum.com/show...gear+installed
I shimmed mine with this kit:
http://www.jegs.com/webapp/wcs/store...tegoryId=18435
Five dollar, much cheaper then $$$$$$ for a new distrib.
One more ? then. Could my bad idle and light load driving issues be caused by uneven compression? It does have 181K miles. What are your thoughts? Let me add this; I had the throttle body rebuilt, replaced EGR valve and injectors. This fixed other problems I had but not this.
Bottom line, From what I have and what you might be saying is that I need to do a rebuild soon. If so what price range would I be looking at for a close to stock engine?
Post them for us to look at.
