smog crap
Old Sep 24, 2006 | 08:39 PM
jimmya's Avatar
jimmya
Default smog crap
after pulling spark plugs one more time, i think i have decided to cut off the smog tubes/pipes and plug/block off. they are nothing but in the way for my fat hands.i know a lot of people do this, any problems with it?
Old Sep 24, 2006 | 08:55 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I removed all that crap without a single problem. I mig welded the holes with the manifolds still on.
Old Sep 24, 2006 | 08:59 PM
jimmya's Avatar
jimmya
Default cool
you and me must be a lot a like.thats what i wanted to hear.
Old Sep 24, 2006 | 09:04 PM
87vette's Avatar
87vette
I just might end up doing that since I have a buddy who has the tools to do so. I'm getting tired of it myself right now. Could use some hooker headers but I don't see that happening for another few years.
Old Sep 24, 2006 | 10:23 PM
Thrak's Avatar
Thrak
I used $0.49 plumbing caps from Home Depot to cap mine... works great, cheap, and looks pretty darn good!
Just did it this weekend and pulled all that crap off... also plugged the cat w/ a 3/4" bolt... screwed right in!
Old Sep 24, 2006 | 11:48 PM
zoro's Avatar
zoro
I did the same, but those tubes extend into the exhaust pipes. It would be better to take the exhaust headers off and trim the tubes.
Old Sep 25, 2006 | 09:16 AM
ODIVETTE's Avatar
ODIVETTE
You own a corvette - treat it right. Instead of cutting those tubes, you might as well eliminate the entire pollution control set up and gain gobs of power.My advice is to spend a little bit of money and throw long tube headers on it. Eliminate the cats and it will look better, perform better, and it will cost little.
I did a complete rebuild and I can remember slicing my hands open on the heat sheilds, crushing my hand bones inbetween the stock manifolds, etc, as I took them off. The headers freed up a lot of room and install from the bottom in minutes. By far the easiest set of headers I have ever installed. And my car doesn't look like someone got in there with bolt cutters and hacked it apart.
I do all of my own work, so I would be embarassed if I was showing my car off and someone noticed that I hacked anything on the car. Plus...if you ever want to restore the exhaust system to original, you can.
Old Sep 25, 2006 | 03:44 PM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
welded shut, i like that idea!
Mine are capped off with thick rubber caps that came with my pulley kit.
Old Sep 25, 2006 | 11:07 PM
AGENT 86's Avatar
AGENT 86
Heres my view If your looking for any kind of performance improvement, forget it, get headers. If your not a fanatic and are soley doing it to ease spark plug installation and clean up the engine bay, weld it on the spot. If your really worried about looks, spend a few painfull hours of re and re and make it look right. I did it soley for spark plug ease and part of cleaning up the engine bay. Here is an pic from when i tore it down for the rebuild.
Old Sep 25, 2006 | 11:12 PM
Jack_leg's Avatar
Jack_leg
I had the 85 IROC with the same TPI system. I took off all that crap and all I got was better fuel econ and ETs. No problems.
Old Sep 26, 2006 | 09:06 AM
GIJoe's Avatar
GIJoe
wow nice! I am going to have to talk to my buddies that do welding now
To smog crap
