88 Dash Goes Dark When lights Put On
Old Sep 25, 2006 | 06:29 AM
Da Mail Man's Avatar
Da Mail Man
Default 88 Dash Goes Dark When lights Put On
....greetings all,
.....just had this problem pop up last night and noticed it when bringing home a pizza, and due to lack of light, i didn't have time to check fuses or check the helms.
.....the problem is when i turn my key to "on" and start my car to "run", the digi dash is lit as normal. however, when i went to pick up my pizza and turned on the lights, the entire dash went dark. it is functional as i can see the unit working but, nothing lit up.
....i won't be able to check the fuses until late afternoon but, figured i'd get a jump on this before i do. what do ya think the problem is?
.....**now, i have a thread started having to do with the csv temp switch and in that thread, i grounded the tan/brn wire to the csv to ground to bypass the switch..........however, i don't see the correlation between the two...........thanks again!
Old Sep 25, 2006 | 07:04 AM
LD85's Avatar
LD85
mine did this when my 4+3 OD relay wires touched each other.
Old Sep 25, 2006 | 07:26 AM
Da Mail Man
......was able to get a few minutes this morning and checked all the fuses......blown fuse....fixed........spike that football!
Old Sep 25, 2006 | 07:38 AM
tomtom72's Avatar
tomtom72
St. Jude 15 Year Donor
Active Streak: 90 Days
St. Jude Donor '08 thru '26
wish everything could be that easy!
Old Sep 25, 2006 | 07:39 AM
Da Mail Man
.....no $hit!
To 88 Dash Goes Dark When lights Put On
