backfire out of tail pipe
Old Sep 14, 2001 | 01:44 AM
ICANTDR55's Avatar
ICANTDR55
Default backfire out of tail pipe
I have 1992 corvette coupe. It takes about 5-8 second before the car will start. I guess you could say extended cranking time. When it does start, the car miss until I rev the engine a few times and it clears up,But after this it backfires out of the tail pipe at idle. I can give it a little rpm and it still backfires but clears up. can anyone tell me what is causing the extended cranking and backfire problem? :( :(
Old Sep 14, 2001 | 04:46 AM
Stratocaster's Avatar
Stratocaster
Default Re: backfire out of tail pipe (ICANTDR55)
too many....
you need to get us more info... could likely be spark related.. start there, give a shout back.
Old Sep 14, 2001 | 05:18 AM
GlockLT4's Avatar
GlockLT4
Default Re: backfire out of tail pipe (Stratocaster)
Yeah.. you could be dumping fuel/air mixture out your exhaust while you're trying to start it.. and once it gets started, all that stuff just explodes.... I'd say spark too....
To backfire out of tail pipe
