Rear bumper cover
Old Sep 27, 2006 | 12:33 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default Rear bumper cover
While backing up, I backed into a branch. I now have a crease running about 8 inches starting from the just over the brake light and running down the side.
Is there anyway to take this crease out?
Old Sep 27, 2006 | 12:49 PM
Pete K's Avatar
Pete K
Careful heating with a heat gun is the only way I know of. If not, they make a special rubber bondo.
Old Sep 27, 2006 | 12:57 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
, the bondo would be the best bet
Old Sep 27, 2006 | 01:01 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
thanks, but I have never heard of rubber bondo. Where can I get the stuff and is there anything I need to know beforehand?
Old Sep 27, 2006 | 01:04 PM
Pete K's Avatar
Pete K
It is a 2 part epoxy that is sold in body supply places. You will need to grind the paint off the damaged are and 2 inches into the good, surrounding area. Feather the edges. The surface must be rough for good adhesion. Thn mix according to directions and allow to dry. If I recall correctly, a heat lamp is recommended. Finish it as you would bondo, then repaint the bumper.
Old Sep 27, 2006 | 01:33 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Thanks very much!!
To Rear bumper cover
