No fuel
Old Sep 29, 2006 | 11:24 PM
alvinr's Avatar
alvinr
Default No fuel
Am rebuilding a 92 with 150k miles. Engine was rebuilt shortly before I bought it, but car has sat a lot. I have spark, and engine runs if I introduce fuel through intake. Installed new pump, put in fresh fuel. Checked fuse in fuse box. What did I miss?
Old Sep 30, 2006 | 12:49 AM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
Do you get any fuel pressure on the shrader valve ?
I would test the fuel pump on the ALDL.
Then fusiable link, fuel pump relay, oil pressure/fuel pump switch, module, wiring....
I'm having the same problem.... Fun...
Old Sep 30, 2006 | 01:13 AM
Jack_leg's Avatar
Jack_leg
Have fun, be dangerous, and use a spray bottle with gas! That’s always fun… Or you can just be a conventional stiff like the rest of us and check the pressure with a gage at the rail.
Old Sep 30, 2006 | 07:29 PM
alvinr's Avatar
alvinr
No fuel in lines from changing fuel pump. The GM Shop manual suggests that the SCM may be giving a fault, or otherwise the relay. However, to do the diagnosis you need a GM Tech I tool. I know about OBD I and II scan tools, will they work? I thought the Tech tool was bidirectional so you could send signals to check components as well. If the Tech I tool is different,where do you get one, other than $G$M?
To No fuel
