Need Tech Help - BTF, TJ, etc
I am helping set-up a fully built 3-rotor (Japanese only) with a large turbo application. All of this is custom. Due to the fact that the cylinder head has two seperate intake tracts per rotor, the intake has been fabbed to allow the use of a single small TB (Chrysler 1.8L TB) and the larger entries have a large TB (LS1 TB).
My issue is that the small TB still retains the mechanical cable to open, while I am trying to operate the second TB via DBW (drive by wire). The idea is to have the second TB open based on TPS (from the first TB (0-5V analog signal) and the MAP reading. I was trying to get the second TB to begin opening based on 108kPa and 2.5V TPS. The second TB would progressively open by reference from the TPS signal and 160kPa MAP signal. The second TB DBW requires a digital signal to actuate.
When I look at FAST, BS3, Haltech, they have simple signal out that would actuate an external device, but I am not sure what I would need to do to accurately accuate the digital driver on the LS1 TB from the analog output from the aftermarket ECMs.
I know this is way out there, but any info would be most helpful.
Thanks in advance,
Aaron
either way you could setup an output that was PWM (like an injector driver) The other option is a seperate circuit that has a PWM driver on it and functions according to rpm and map. You would use the spare output on your BS3,halltech etc for activation of the circuit.
yet another way I could think of doing it is using a greddy emainge ultimate ( I install like 3 a month) and use the sub injector outputs to control the secondary throttle.
the only possible hiccup would be the current demand, possible requiring a heavier driver.
It is possible.. but, that is one hell of a risky thing to try and do by yourself and could be a liability if something went wrong which is exactly what was happening with the early DBW vettes... if that DBW TB malfunctioned for some reason it could get someone in a bad situation in a hurry. if the main throttle is cable opened, and you are wanting to operate the larger TB in sequence I would look into more of a dual quad setup where once the smaller TB has reached its max throw the larger TB begins to open on the same cable. this will still give you the entire opening of the first throttle body before the larger one begins to open which will yield excellent part throttle driveability and still give you max flow on the larger one when they put their foot in it. a spring actuated barrel would work in this application.. just something to put some thought into. throttle opening is kind of a hairy situation.. especially on a HIGH HP application.
Chris
thanks for the response. It has been about 15 years since I went through college EE classes, I am a ChE/MBA). Could you detail exactly the thought process on the seperate driver that drives the PWM driver, and how that could be integrated into the avtermarket ECM set-up, which is now looking like Haltech.
Thanks again to all who returned with comments.
Aaron
I'm sure if you are using any kind of after market ECM system they will have a configureable on/off output like that. My Accel Gen7 has two of them with configureable tables depending on map reading, rpm, and throttle possition.
By the way those 2.0L rotaries really rock! It should be a great motor when its all done and you crank the boost.
Thanks for all of the words of wisdom and encouragement. This motor is a 3 rotor (basically an additiaonal 1/2 motor attached to a standard 2 rotor engine). It was only available in Japan, and required considerable work to get it to fit in the std RX7 chassis. That is all behind us now.
We can concentrate on the twin TBs. I do still like the idea of electronic control of the secondary TB, so I will continue to ask questions on that front. This package should run on 20+ psi boost, and the 108kPa indicated is indicative of no boost, no vacuum (basically atmospheric psi).
More input please.
Aaron
That sounds great. I will patiently await your response. If we can get this to work, then this would be basically "the best of all worlds" with respect to the airflow requirements on the dedicated intake tracts.
Thanks for helping me out on this project. This forum is a great place.
Aaron
The processor uses a crank trigger or something like a 36-1 or 60-2 (the minus being missing teeth) once it has "sync'd up" it knows via the time between each tooth and the count of which tooth it's on to decipher where the crank shaft position is +/-some% depending on processor speed and programming.
Then it's a simple matter of telling which of the 6 coil drivers (for c.o.p) or 3 for wasted spark when to fire, as in firing order. It will charge and spark the appropriate coil according to your timing map. But I beleive there is like 30deg or so difference judging from the cap & rotor on my 12A.
You can read much more about this on the megasquirt website, the MS-S extra code has been successfully adapted to rotories. They probably explain it better then I can.
1) We can try to use the tach signal to trigger a transistor controlling the output of a variable current source, mastered by the tps signal(or map).
This strategy would open the throttle as a function of rpm/throttle(map) position. kinda like a vacuum secondary and wpuld be totally independant. Set with potentimeters.
2)we can create a pwm driver circuit that remains at a fixed freqency and the current leg shall be fed by your spare output lead on your haltech. non-linear but simple.
what i really need at this point is some info on the drive motor. I.e. current demands, how is setup in the factory effort (LSX) to get an idea for parts that would be involved
what would be the advantage of running two throttle bodies??
how about haveing 1 BIG body with a custom cam on the body?? this would give you, if built right, a very ajustable throttle, but still the flw at full throttle!
thanks Chris.
