Swapping Computers
Here is what I was told:
WinALDL is a 160 baud program. That means it collects data from the slow
ECMs. The ECM found in the 86 Corvette (the 1227165) is a dual baud rate
ECM - it talks at either 160 baud or 8192 baud. From what a few
customers with those early 86 Corvettes have described to me, I'm not
sure that GM incorporated the ability to switch over in to 8192 baud
mode with those ECMs. It's like the chip doesn't support it. Now, if
you're running an aftermarket chip (or thinking about burning your own),
then there's a good chance that your ECM will talk at 8192 baud - which
would allow you to run Datamaster. It's easy to change to a newer chip
image if you get a custom chip or burn your own. There are plenty of
chip images available in the GMECM .bin file archives.
