LS1 in a C4?
Old Oct 1, 2006 | 05:10 PM
James Paradiso's Avatar
James Paradiso
Default LS1 in a C4?
I have an 86 C4 and recently came across a good deal on a 96 LS1 with tranny and rear. Has anyone ever dropped this motor in a c4???
Can it be done????
Old Oct 1, 2006 | 05:14 PM
ToniH's Avatar
ToniH
Here is a topic never discussed here before
Do a search...please.
Old Oct 1, 2006 | 05:16 PM
JJ 86's Avatar
JJ 86
Can it be done????
If it is a 96 LS1 I would pass. I believe that 97 was the first year for the LS1.
Old Oct 1, 2006 | 05:18 PM
Draven's Avatar
Draven
St. Jude Donor '14
Do a search, too.
Old Oct 1, 2006 | 05:26 PM
bogus's Avatar
bogus
there are a couple of mile long threads involving just this topic... if you don't feel like searching, then go to the C4 Tech FAQ (sticky) and look for the links in "Online References".
the LS1 started in 1997.
Old Oct 1, 2006 | 06:59 PM
~db~'s Avatar
~db~
Old Oct 2, 2006 | 02:00 AM
LS6 Motor's Avatar
LS6 Motor
As stated above, the introduction of the LS1 came in 1997 along with the C5's. It was put into the Camaro's in 1998. The best years were later ones, with the introduction of the better intake manifolds, and higher lift camshafts in 2001 for the Camaro's.
I have a 2001 Z28, with the LS1 motor, and actually just found out that they ran out of the LS1 blocks, and some cars had LS6 blocks in them. Apparently I was one of the lucky ones, because my Z28 has a LS6 block, but still only the LS1 heads.
With just a SLP catback exhaust, SLP lid, and a tune using LS1 edit, this car put down 348 RWHP which to me is astounding with the 6-speed, and a 3:42 rear axle. I can only imagine what a cam, head work, and some headers would do
Old Oct 2, 2006 | 02:16 AM
bogus's Avatar
bogus
there is a difference between LS1 blocks (Z06 v. base)? I was always under the impression that the blocks were identical, and the heads/intake was where the major differences occured.
Old Oct 2, 2006 | 07:56 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
According to the Black Book, only one block for the entire run of the C5, 12561168-block. LS1 head-12564241,LS6 head-12564243.
Old Oct 2, 2006 | 12:19 PM
bogus's Avatar
bogus
Exactly what I would have expected to hear... someone is getting sold a pile of something stinky...
Old Oct 2, 2006 | 01:30 PM
neat's Avatar
neat
There is a difference between the LS1 and LS6 blocks. The LS6 blocks have a different windage system inside, and there some structural differences that add strength.
Normally I wouldn't question the black book, but it's wrong in this case.
My Mom has a 2001 WS6 with a Vortech. About a year ago she broke a piston and we used built an 04 LS6 block for her. You could see the differences in the blocks with the both oil pans off.
There is also a difference between the LS6 blocks. A 2004 LS6 is different than a 2002 LS6 block.
Like I said, I normally wouldn't question the black book, but I have some first hand knowledge on this one. The black book is wrong on this one.
Hop into the C5 ZO6 section, I am sure they have covered this there.
To LS1 in a C4?
