Throttle performance switch?
Is it worth the time & money? or just a get rich quick invention?
anyone used it before? If so what were your thoughts about it?
The factory calls for 6 degrees. Just advancing it 4 degrees gave it a sizeable boost in low end torque with no ill effects.
Also, if your engine has more than 100K, it's a good idea to change the timing chain. Just a little bit of slop in the chain retards timing and costs you power.
The "Throttle switch" is snake oil.
it takes off a LOT faster than it does without it in there.
My only problem with it is, they don't last long, Mine died after about a year or so, as did a couple of other people I know that have them.
After reading all the timing stuff though, I am considering doing some of this instead of replacing it ... hrmmmm
Have you actually OWNED one?
Didn't think so.
You can't push your foot through the floor, it only goes so far. Without it it takes off nice, with it on, it pulls harder off the line, is capable of breaking traction much quicker, etc. You can't say it doesn't do anything if you have never used on personally. I am not saying I know how it fully works or how it may or may not benefit anytihng but THERE IS A BIG SEAT OF THE PANTS DIFFERENCE WITH IT ON WHEN YOU PUSH THE PEDAL TO THE FLOOR.
If I can pull away from someone much quicker in a race than I can without it, then how exactly am I dreaming?
Would I buy one had I know about it now? No, probably not since everyone bad mouths it. I bought that switch (along with teh super duper awesome useless airfoil) when I first bought my car years ago before I had the CF to ask questions about
The only way to find things out sometimes is to just find out for yourself.
I would tell someone if what I did was a pointless waste of money, and many things I have done just that and said so... but you can actually feel this thing doing something.
Didn't think so.
There is only 1 WOT, and it doesnt come in increments.
But I used to play with timing on my el camino before it became a serious racer and the more timing it got the stronger it would launch but you could over and under time it so it would do nothing but sit on it's face at the line and/or down the road. It's currently set so It'll throw the nose up at a stand still without stumbling.
But I'm no expert on the L98 or fuel injection setups. to me it seems the one with the switch would launch sooner if everything was timed perfectly.... G-tech? (and traction was present)
I like how every time someone posts something controversial like this, the main response is "show me dyno results, show me 1/4 mile times"....
well how about you guys do that? why should the person that says "yes it actually seems to do something" always have to prove himself right? Why can't you guys spend your own time and endless money that you all seem to have on money trees to prove these people wrong?
yes, I will definately test it all when I goto the track, but for now, I will continue to say "yes it gets me off the line quicker than it did before"
That whole concept is one reason I like nitrous. It's performance with an on/off switch.
sure this throttle thing won't make me any "faster" but it will get me out ahead of someone tearing off the line just a little faster.
It sure is fun driving with it on though...
If you want to do a quick analysis, try this; Rotate your engine to 0 degrees on the harmonic balancer. Remove the distributor cap. Rotate the engine backwards until the rotor begins to turn. Note how many degrees the engine turns prior to the distributor moving (let's say it's 6 degrees). Divide that number in two, and that's how many degrees of timing advance you're losing due to a sloppy timing chain. In your example, 3 degrees of timing advance are lost due to chain slop.
A couple of degrees of retarded timing makes a big difference. I changed my timing chain at 145K miles, and it was very sloppy. I immediately noticed a smoother idle, better vacuum signal, MUCH better performance off the line, and just a healthier sounding engine. You're not really gaining anything....just gaining BACK what the engine has lost over the years.
Don't buy the throttle switch. Think of it this way....yes, it sends a WOT signal at 60% throttle. But how long does it really take you to mash the pedal to the floor as opposed to 60% of the way there? There's a reason that 99.9% of the folks on here call it crap. If you want the same effect for free, tinker with the voltage settings on your TPS until you find something that makes you happy and doesn't set a DTC.
, but would I have to disconnect anything?
