1988 No Start Conditon
Currently testing wire circuits for continuity/voltage. I may find the problem by the time someone responds but things are driving me whacky right now. I am hoping that the resistance key, resistance pellet and starter decoder are all the same--how would you really test this too? Bill Texas I could drive this thing if I could get it started!!!!!!!!!!!!
The start enable relay is located behind the instrument panel about in the center in what looks like a plastic box with no cover called the ,"multi-use center".
The theft module doesn't prevent a start, only the VATS module does.
If you have the correct resistance on the wires going the VATS module and the start enable relay won't close, but the relay is good, then you have a defective VATS module. If you need any further help, let me know.
Since my initial post, studying wire diagrams helped stupid me figureout that the "enabler" is the "relay" in the Center Panel area. I also figured out that the theft controller primarily affects the door locks--assuming the door systems check out, then none of it should really affect the "cranking" part. I get good voltage at all the fuse connections (Theft, VATS, Ignition, etc)
The meat of the issue for getting juice to the starter solenoid to crank is for the ignition switch "SOL" pole in the start position to send 12 volts to the "relay". At the same time, the Key resistance is checked at the "theft module cavity "U and T" and if okay another voltage is also sent to the relay cavity B which then allows relay current to be sent to the "neutral safety" to the bulkhead connector and then to the solenoid. All working properly-----the starter should crank (but not in my case yet).
I will tackle this affair one more time tomorrow and I need to make sure that all my door stuff is functioning correctly, or that the tumbler issue isn't the problem, or that the "decoder" is bad, or that my resistance items are mismatched, or that . . . I WILL NAIL THIS DOWN YET!!!!
Thanks again so much. I know these type questions and verbose replies suck. I just needed some advice and I had to get it off my chest. Belton, Texas
Sounds like the motor or heads are not original.
Incidently, I removed all the evaporator stuff and had to drill the plug out--took a 1/2 inch hole before an easy out would start working!!!!!! Was getting really close for me. As of this moment I have completed a reconstruction of the rear tub, replaced a corner section of the rear RH fender, replaced the rear frame cross-member and back 7 inches of RH frame rail, professionally had rear frame moved about 1/4 inch to get frame correct, repaired/troubleshoot everything, replaced both front and rear bumper to original and now in "no crank" condition. As soon as I figure out how to get to and replace the Neutral Safety Switch on top of the clutch pedal I think she will crank (will use a jumper on connector test as Jfb suggested). The entire wire circuit checked out except for this switch.
The car probably sounds like a mess but she cleaned up well. The car is really, really starting to shape up--new top and paint this December and she will look great! I have been doing all this while I have my 58 and 72 convertible in full body off restoration too. Good thing I don't have to go to work????????????? All is very well now. Bill
