Thoughts on engine build???
My 91 L-98 is aproching 170,000 miles on it and starting to burn a little oil. No big deal. I am about in that place in my head where I will roll out the tool box and tear into the engine compartment, any day now.
I am no stranger to building SBC engines,,,,, been doing it for decades. I've had my fill of building engines with the latest all-out hi performance stuff and I've rebuilt a few for the family suburban, and even one for an asphalt paving machine. I guess I'm kinda burned out. Shurly, there are more like me on here.
Now the question! I want to rebuild this one so that it is an improvement over stock (for sure) but not a tempromental (must have mechanic on board) pain in the @#$#2 for my wife to go shoping 75 miles away. Just a nice respectable but agressive ride.
What would you do???
350 or 383? Stock fuel system or some upgrade? Stock or forged rotating assembly? Aftermarked heads of rebuild L-98's? Chip?
All this depends on how much power you want out of it. I can see you want it tame, but theres an intake choice to be made.
A chip is necessary if you do anything like this.
You guys are pretty much right on. My wife will probably drive it more than I. But If I am driving it I don't want to be imbarassed if some rice-burner revs his engine at me at some trafic light. And we do have some 95 MPH speed limits around here somewhere, or so I've been told.
I'll probably go with the 383. What about rod ligenth? Stay 5.7"?? Pistons to keep it around 10 to 1 cr??? I've put Comp cam's in my other 2 vetts and love their stuff. I'll probably check out their milder cams (still more agressive than stock). However, I am open to other brands so recommend away.
My other Vetts are earlier modles with maf sensors in the intake system. These were always the bottleneck in performance upgrades and made it pointless to try for too much in flow gains. My 91 doesn't have that handicap and I am on new ground here. Can I hog out the throttle body and go for bigger tubes to greater advantage on this one? What else can I do with this set-up that I couldn't with the MAF models?? Will 30# injectors be a good choise to go with the afpr?
Thanks for any input.
Only thing that I'd be less inclined to do on a MAF car is a SuperCharger, otherwise its all the same, except a MAF car doesnt require the chip to be done after minor mods, SD cars do not respond well until the chip is done.
I am using a Scat crank, speed pro hyper pistons, gm pink rods, LPE 219 cam, LPE SR, LPE longtubes, 1.6 summit (scorpion) rocker arms, ported Dart Pro1 heads (200cc), 52mm TB, and I am making 338rwhp/396rwtq. 10.1:1 compression
Frankly it was cheap and it runs really well. Very streetable and not too much power for the 315s. I was thinking of doing more to it, but I think I will port the intake and call it good. Honestly, I beat a 650hp built (i.e. good suspension) Cobra the other day, all that horsepower can hurt on the auto-x course.
Good luck!
