Airbox help
Old Oct 2, 2006 | 05:47 PM
fc_soldier's Avatar
fc_soldier
Default Airbox help
VORTEX RAMMER COLD AIR SYSTEM are they worth $280?
I heard and know of the cutting of the airbox and getting a K&N but I dont want to do that to mine.
What is the best airbox but a good price to?
Old Oct 2, 2006 | 05:50 PM
vader86's Avatar
vader86
No, its a piece of junk. Quality is awful and the performance is not as advertised.
SLP is the one I have, but it is not going to give the power that is advertised either.
Old Oct 2, 2006 | 06:05 PM
fc_soldier's Avatar
fc_soldier
DO think its cost worthy or no?
I got the paper stock filter in now.
What about the one with the 3 filters at the end?
Old Oct 2, 2006 | 06:50 PM
JEFNLSA's Avatar
JEFNLSA
That's the SLP, I have it on my car. Looks good, sounds good...performance gain? Probably not much...
BTW...Welcome! Nice color choice!
Jeff
Old Oct 3, 2006 | 09:23 AM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
no they aren't worth it for the price you pay. About the best option is to cut your lid (free) and get a K&N filter in there.
You could also run new hose and get a cone filter down there too (i made a short ram, but plan to make it longer and get it back to the stock area soon). That was a few dollars in hoses and clamps from the hardware store and a cone filter from the auto parts store.
Don't bother with the BPP ramair crap. BPP stands for Bad Performance Products I was going to buy one when they first came out. They had dyno numbers for their Late C4 and C5 cars, but none for the Early C4 cars. They also refused to talk about it when I asked them... which leads me to believe, its a POS compared to the LT1/LS1 models.
Old Oct 3, 2006 | 09:40 AM
fc_soldier's Avatar
fc_soldier
I have the LT1 so should I just go with buying the open lid and K&N. I saw a kit that does the same thing as if you cut your airbox. I rather have the Original parts.
Old Oct 3, 2006 | 09:55 AM
tlong's Avatar
tlong
The K&N does not fit the stock airbox very well. They give you some grease to try and seal it. SLP is much better. Recent article in Corvette Enthusiast Mustang Dyno says 6 hp.
For the hundredth time
Old Oct 3, 2006 | 10:20 AM
runner140*'s Avatar
runner140*
I have a SLP but this is not a true cold air system. It still works for me.
Old Oct 3, 2006 | 11:26 AM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
I was looking at the SLP CAI ($267). I understand HP gains is questionable, but can you describe any WOT sound difference between this and the KN open lid filter.
Old Oct 3, 2006 | 02:08 PM
GIJoe's Avatar
GIJoe
the cut lid w/K&N sounds about the same compared to stock. It just breathes better because you don't have it sucking air through a teeny group of slits anymore.
The CAI's won't get you much more of a gain because its still pulling the same air from the same area.. it just might breath a bit better, but with a cut air lid, you are about as good as you are going to get. About the only gains you will get from one of those CAI kits is it looks cooler and you might get a few mors horses out of it. Certianly not worth $267...
Old Oct 3, 2006 | 05:24 PM
arkangel81's Avatar
arkangel81
u r better off cutting the aluminum airbox lid, getting a K&N insert, and saving $200. you can always make it look professional by bomb-canning the lid a sweet color to match your vette as well. save a few bucks and do it your self.
Old Oct 3, 2006 | 06:51 PM
Zix's Avatar
Zix
I haven't noticed this? I have two K&N filters for my LT4 (so I can have one in there while I clean and re-oil the other one if necessary) and they both fit fine and didn't come with any grease.
Old Oct 4, 2006 | 12:46 AM
Hotred94's Avatar
Hotred94
Honestly I don't know of any airbox that is worth the money. Do a full cut lid. Then you can buy roller rockers instead.
Old Oct 4, 2006 | 09:55 AM
arkangel81's Avatar
arkangel81
Old Oct 4, 2006 | 10:12 AM
wro87's Avatar
wro87
CUT the LID! If you want you can pick a new one up on the internet or local junk yard if you want to keep your old one. The filter is no problem and you can tell right away that it is breathing better. It is a CHEAP fix and worth the fact that you are getting more air in. wro87
Old Oct 4, 2006 | 10:53 AM
fc_soldier's Avatar
fc_soldier
Alright Ill do it you guys twisted my arm. Does anyone have pics of this being done? Someone give me a brief overview.
Old Oct 4, 2006 | 10:54 AM
fc_soldier's Avatar
fc_soldier
What rollers do guys think are the best? Im new and open to suggestions.
Old Oct 4, 2006 | 12:28 PM
GIJoe's Avatar
GIJoe
basiclly whatever is not holding the filter down, cut it out of the lid.
you want to leave the outside frame and thumbscrews to actually hold the filter to the airbox, but cut away everything else so the filter will be left completely exposed.
it is hard brittle stuff, I cut mine up with an anglegrinder. you can probably do it just as easy with some cutoff wheels and a drill.
Old Oct 4, 2006 | 01:09 PM
wro87's Avatar
wro87
As suggested use an angle grinder or a small jig saw. Cut it right were it meets the top of the filter (one big square hole). As for the rockers I went with some self alineing roller rockers and reused the guide plates. you will have to grind off the tabs under the valve covers or use some tall covers if you want. The downside withsome of the taller valve covers is that you will have to remove them if you want to get to some of the bolts on the intake. wro87
To Airbox help
