Ok What the hell......?
Old Oct 2, 2006 | 11:38 PM
cplonner's Avatar
cplonner
Default Ok What the hell......?
I have had my car running fantastic lately. The other day I pull out of the drive way and get half way down my street and the check engine light comes on and a second later the car dies dead in its tracks. Fuel was fine, I had no spark. I got a code 42. I inspected all the wires and everything looks fine, all connections are good, cleared codes tried a few different things, nothing.
Today I go to dig in the engine again to find out whats going on but before I do I try starting it again. The car starts right up perfectly and is still running good.
What the hell is going on? Any ideas? I figure maybe a ground somewhere but everything looks good. Is there something that could slowly be crapping out in my car, or a faulty ...somthing?
Old Oct 2, 2006 | 11:43 PM
bogus's Avatar
bogus
42? I don't remember what that code means... bump.
Old Oct 2, 2006 | 11:48 PM
cplonner's Avatar
cplonner
Its the wiring coming from the distributor having problems. That is what chevythunder.com said at least.
Old Oct 3, 2006 | 12:12 AM
bogus's Avatar
bogus
I was thinking it had to do with the EST system....
Old Oct 3, 2006 | 12:31 AM
RRT vette's Avatar
RRT vette
Code 42 is the EST connections or wiring. Sounds like you lost spark when hot, as if you have a defective ignition module.
Old Oct 3, 2006 | 09:03 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Check your ICM (ignition control module).
Old Oct 3, 2006 | 10:09 AM
cplonner's Avatar
cplonner
Ill take a look today, I dont want to get stranded with this car somewhere when this thing decides to die again.
Old Oct 3, 2006 | 10:18 AM
runner140*'s Avatar
runner140*
Check the ICM, coil and coil wire for starters.
Old Oct 3, 2006 | 05:57 PM
williammackean's Avatar
williammackean
St. Jude Donor '07
Interesting:
42 is the code for the Vette's Life, Universe and Everything...
Old Oct 3, 2006 | 06:54 PM
cplonner's Avatar
cplonner
Still havent got a chance to look at it yet, been busy all day, but it has started missing again. It was doing this earlier and I couldnt figure why it was missing. Would the fact that it is missing give any more hints to what component it could be?
lefoy84's Avatar
lefoy84
Originally Posted by williammackean
Interesting:
Can I have some of what you're smoking?
Old Oct 3, 2006 | 07:51 PM
redrose's Avatar
redrose
ign module in the distrib is suspect...get a used one from the j-y or a discount auto parts new for $20...put the tools to change it in the glove box
Old Oct 3, 2006 | 08:06 PM
rick lambert's Avatar
rick lambert
First you can have the ICM checked at autozone....second don't bother wit a JY there on about $30 new
kize's Avatar
kize
Also check factory ignition module wiring harness. Mine crumbled to dust when I took the cap off and inspected the module in distributor.
Old Oct 3, 2006 | 11:24 PM
cplonner's Avatar
cplonner
Alright, I have a high performance one from a while ago that is still good so I will check the wires and put that in tommorow and see what happens. I note that the miss only occurs when the engine is at operating tempature.
Old Oct 11, 2006 | 05:11 PM
cplonner's Avatar
cplonner
Ok guys, I would just like to let you know that I figured the problem out now. Thank you for your help. There was a pink wire with a white female connection that goes into the tach/bat part of the dist. The inside of the connector (metal connection) had broken apart and was creating a really bad connection. I have replaced it and now the car runs much better. Thanks for all your help!
Old Oct 11, 2006 | 06:12 PM
ultraviolet70's Avatar
ultraviolet70
Thanks Cplonner. I love it when someone finishes their threads by actually posting the fix.
To Ok What the hell......?
Old Oct 11, 2006 | 09:03 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default fix
dontcha just love a party
Old Oct 11, 2006 | 09:24 PM
C4boy's Avatar
C4boy
I couldn't agree more. Nothing worse than finding a thread for similar symptoms and no resolution.
Old Oct 12, 2006 | 12:26 AM
cplonner's Avatar
cplonner
Yeah the wiring looks pretty brittle, I think at some point Im going to have to replace most of it. Maybe by then ill have my new truck and some time to do it. Hopfully what is there will hold for now.
