clean injectors off the car
Old Oct 4, 2006 | 06:12 AM
USCG's Avatar
USCG
Default clean injectors off the car
Other than taking the injectors to a "shop", what's the best way to clean the injectors while they are out of the engine..?
I thought of letting the "business" end sit in some carb cleaner, and have read the warnings against totally immersing the entire injector in any sort of cleaning agent, but is there a preferred method..?
Old Oct 4, 2006 | 07:36 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Bump..... Id love to hear some sugestions too
Old Oct 4, 2006 | 08:24 AM
VenkmanP's Avatar
VenkmanP
It's worth paying to have it done right. You can cycle the injectors by applying voltage while spraying cleaner through them, but it won't do nearly as well as a proper cleaning.
Do a google search I'm sure you'll find lots of pages on DIY injector cleaning.
Old Oct 4, 2006 | 09:10 AM
runner140*'s Avatar
runner140*
With the "blue top Ford's" 24 lb. selling for $200.00 shipped from Summit Racing, if I had or suspected injector problems, I'd buy a new set. JMHO.
Old Oct 4, 2006 | 09:27 AM
Wheelman's Avatar
Wheelman
Happen to have that link or part number handy?
Old Oct 4, 2006 | 10:16 AM
LS6 Motor's Avatar
LS6 Motor
As stated above, the correct way is to have them cleaned professionally. Typically they are checked electrically by ohming them out.
If yours are the RP Mulitechs, they should be 16.5, +/-, .3 according to the factory service spec. If they are outside this range, the coils are bad. That is the problem with the Multitech's, the gas cools them, which is obviously a solvent, so over time it breaks the windings down.
Finally, they are usually ultrasonically cleaned, and then flow tested. This service will usually be in the $100 - $125 range, so for a little more money, and you already have them out, why not replace them? Don't be like me, and pull it down to the intake......5 times, before you finally replace them
Old Oct 4, 2006 | 10:38 AM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
If they are the original Multec crap just replace them now and save the aggravation and $$$$$$$
Old Oct 4, 2006 | 12:19 PM
Muffin's Avatar
Muffin
Simple, Rich at Cruzin Performance.
Old Oct 4, 2006 | 12:57 PM
kennedys22's Avatar
kennedys22
Default just had Ford's installed
I installed, or had installed for me, 8 new Ford injectors for my '91. I paid $495 - Summit is much cheaper! The car is running great. The advice of my mechanic, as well as other posts, if you're in there replace all of them. They go bad and you may have to go back in. All of my idle issues and lag were corrected. One bad injector. If you have the engine apart I would replace them.
Old Oct 4, 2006 | 05:28 PM
USCG's Avatar
USCG
Here's the site for anyone interested:
www.cruzinperformance.com/fuelinj.html
He is not accepting any injectors for the time being, but at $12 each, it's better than $150 each (new) which is a quote from Autozone+Napa for a Camaro V6 injector (that's one, not a "set").
Summit will sell a set of 6 for the V6 for $85 (GM Perf Parts).......so I would say it pays to shop around a bit...whether it's your Corvette or kid's car.
To clean injectors off the car
