Replacing Rear main
Old Oct 4, 2006 | 11:00 AM
vtvetteman's Avatar
vtvetteman
Default Replacing Rear main
replacing the rear main seal on my LT-1, would you guys suggest replacing all the seals and gaskets now while I'm doing it or leave them alone if they aren't leaking?
thanks
Old Oct 4, 2006 | 11:06 AM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
Ive always been of the opinion that if it aint broke dont fix it unless its a known failure item Like doing a waterpump and an opti at the same time
Im sure others will say while you are in there might as well do it
Old Oct 4, 2006 | 11:32 AM
redrose's Avatar
redrose
imho, i wouldn't even replace the rear seal unless its leaking a whole lot..(oil is cheap)...but then i once owned harley-davidz
To Replacing Rear main
