code 34 is Mass Air Flow (MAF) Sensor (low air flow indicated )
check for loose or damaged air duct between maf sensor and throttle body
if you have a rough or unstable idle
Clear the codes
Start and run engine above 2300 rpms for 1 minute or until 34 sets
do this test and let me know if the code sets. :cool:
