Maf Sensor Help
Old Oct 5, 2006 | 11:29 PM
ZRWON's Avatar
ZRWON
Default Maf Sensor Help
Got my '89 L98 tuned today: plugs, wires, ditributor, relays etc. Starts, idles, and runs much better, BUT only with gentle throttle pedal pressure. Hard or full throttle pressure and it goes flat with no acceleration. Gentle throttle pressure and it easily cruised at 60 mph...maybe could have gone faster but any slight hill and it had a heck of a time making the grade.
Mechanic ran several tests on MAF sensor and looked for codes. None found. No screen in MAF or cats on car.
Mechanic said I need to replace MAF...~$250 + installation. OUCH!Where can I buy one for less? How about a used one from a low mileage '89?
Can I install it myself...degree of difficulty? Before we had computers etc I could do a tune up myself (1950 vintage V8s).
Thanks in advance for the help.
Old Oct 5, 2006 | 11:49 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Did they use a scanner to get this info?
This is a critical test and way to determine if the MAF is indeed bad.
Old Oct 6, 2006 | 12:53 AM
vader86's Avatar
vader86
MAF will give some kind of code fault when its bad. If you dont have Code 33,34,36 or whatever, then theres something else wrong.
Did you consider a fuel pump or supply issue yet?
Old Oct 6, 2006 | 08:39 AM
Dynabob's Avatar
Dynabob
From: What do I know anyway? I'm just a 50 year old No0b
I went through a similar problem just a couple of weeks ago with my '89. Fuel pressure was good and no cats either. I unhooked the cable from the maf and the car ran just as good with it unconnected as with it hooked up. A new rebuilt BOSCH unit and things are back to normal. I got mine from Advance Auto for around $180. Replace both maf relays while you are at it, they are cheap insurance for the new maf. It's really easy to do, no special tools and only takes a few minutes.
Old Oct 6, 2006 | 09:34 AM
RRT vette's Avatar
RRT vette
Good suggestion. Disconnect the MAF with the engine running and see if there is a difference. Usually is the MAF is bad, the ECM throw a code. Make sure your fuel pressure is good and even good when driving at different acceleration rates. Change the fuel filter if you have not. It would be nice to get it on a scan tool.
Old Oct 6, 2006 | 03:47 PM
GlennS87's Avatar
GlennS87
You might want to check your TPS with a voltmeter or a scanner. You shouldn't have to press the pedal on starting generally and it might be falling on its face in the upper rpm ranges if the tps is sending a bad signal. The range should be from about .54 volts to over 4 volts. The important thing is to make sure the transition from no throttle to high throttle is linear.
To Maf Sensor Help
