Quick Dana44 questions
Old Oct 7, 2006 | 03:05 PM
honda hunter's Avatar
honda hunter
Default Quick Dana44 questions
What all is needed to do the swap? Right now the driveshaft is to long so will I need to get another one or can I modify my stocker?
Old Oct 7, 2006 | 03:13 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Some folks have said that the A4 shaft could be used as is. But ideally it should be shortened an inch. Same goes for the C beam, it can be redrilled in the front. But if you did so, I'd recommend using beam plates with it. So, it can be done with just the differential and batwing. But it's even easier if you can also obtain the manual drive shaft and C beam. Then all you have to do is put your A4 yoke on the front of the D44 drive shaft.
Old Oct 7, 2006 | 03:15 PM
honda hunter
How do I modify the A4 driveshaft?
Old Oct 7, 2006 | 03:35 PM
danno85's Avatar
danno85
To shorten the driveshaft you put it in a lathe and cut through the weld on one end to get the end off, then cut however much off the length of the tube that you want to shorten it by, again in a lathe. Then put the end back in the tube and re-weld it all the way around. Best done in a lathe so you can get it aligned well. Then balance it.
To Quick Dana44 questions
