Different Intake System
Old Oct 9, 2006 | 09:27 PM
Happydad's Avatar
Happydad
Default Different Intake System
Well I've pulled my L98 out of my 86 coupe and will start to rebuild it ..A rod knock started this..My question is after pistons and cam mild nothing rad I would like to go to a diff intake sys..And Get rid of that underfed stock intake..I Realy don't want to go big bucks on an aftermarket ie bbk,Holley..what would you guys suggest ?? Lt1 ? What would you have to do to the ecu ? This is new to me I'm old school Tech..Any help or input would be appreciated...
Old Oct 9, 2006 | 09:46 PM
marksp's Avatar
marksp
The lt1 intake is very similar the the TPIS miniram which was designed for the l98 tpi motor. Check out TPIS's web site. That intake makes a lot of power, but its pretty pricey. You can run a lt1 intake but it will have to modified to accept a distributer. Check out this site http://lt1intake.com/services.htm Another option is the holley stealth ram, but it won't clear a stock vette hood, but I've heard it can be modified to fit.
Good luck.
Mark
Old Oct 9, 2006 | 09:50 PM
Strike3's Avatar
Strike3
You have about eliminated everything by not wanting to go "big bucks" (you can easily tie up $1,200.00 + in an aftermarket asperation system.
If you are on a tight budget, you might consider going to a 52MM throttle body and match porting your entire plenium/tubes/manifold right to your head ports. this will give you a noticable improvement over stock an If you are handy with tools, you can do the port matching yourself. Maybe even a little bowl blending throwen in. You really need to find you a set of heads from a later modle L98,,, Maybe 89, 90 or 91. I picked up a set at a salvage yard and they have many advantages over the stock 86 cast-iron version. Port match and blend them as mentioned above for great effect. The later heads are aluminum, and besides flowing better, they disapate heat better and will allow you to set up your engine to run a hole point higher compression (ie, rather than 9 to 1, you can run 10 to 1 with the aluminum before you have problems with pre-detonation (pinging)...all else being the same.
Old Oct 9, 2006 | 09:54 PM
Strike3's Avatar
Strike3
[QUOTE=Strike3]You have about eliminated everything by not wanting to go "big bucks" (you can easily tie up $1,200.00 + in an aftermarket asperation system.
If you are on a tight budget, you might consider going to a 52MM throttle body and match porting your entire plenium/tubes/manifold right to your head ports. This will give you a noticable improvement over stock and If you are handy with tools, you can do the port matching yourself. Maybe even a little bowl blending throwen in.
You really need to find you a set of aluminum (113) heads from a later model L98,,, Maybe 89, 90 or 91. I picked up a set at a salvage yard and they have many advantages over the stock 86 cast-iron version. Port match and blend them as mentioned above for great effect. The later heads are aluminum, and besides flowing better, they disapate heat better and will allow you to set up your engine to run a hole point higher compression (ie, rather than 9 to 1, you can run 10 to 1 with the aluminum before you have problems with pre-detonation (pinging)...all else being the same.
Strike3's Avatar
Strike3
You really need to find you a set of aluminum (113) heads from a later model L98,,, Maybe 89, 90 or 91. I picked up a set at a salvage yard and they have many advantages over the stock 86 cast-iron version. Port match and blend them as mentioned above for great effect. The later heads are aluminum, and besides flowing better, they disapate heat better and will allow you to set up your engine to run a hole point higher compression (ie, rather than 9 to 1, you can run 10 to 1 with the aluminum before you have problems with pre-detonation (pinging)...all else being the same.[/QUOTE]
Old Oct 9, 2006 | 11:45 PM
vader86's Avatar
vader86
read my website
and its not going to come within a small budget unless you do everything yourself and buy nearly everything used, but even then the heads and intake are going to cost you
Old Oct 9, 2006 | 11:49 PM
cplonner's Avatar
cplonner
I think if you spend the extra money you will be happy with it. It wont be hard to build somthing faster than the new c6 if you are going to start from the bottom up. Then you will have a car that is nice and speedy and didnt cost 50 g's.
Old Oct 10, 2006 | 12:31 AM
kopbet89c4's Avatar
kopbet89c4
Happy MiniRam owner right here! Feel it pull strong to 5500 rpms without that "TPI" wall.
Old Oct 11, 2006 | 09:45 PM
Happydad's Avatar
Happydad
Sweeet.....O.K. I'll bite the bullet and look into some mini ram units..Oh BTW I do have alum heads they were stock on the 86 mid year along with the roller cam..Thanks For all The info
Old Oct 11, 2006 | 10:17 PM
vader86's Avatar
vader86
No, you do not have a roller cam.
Roller lifters started in 87. You only have the '128 heads, which are not as good as the 88-91 heads, the '128s need some work done to them, especially with a MR going on the motor.
Old Oct 11, 2006 | 10:32 PM
kopbet89c4's Avatar
kopbet89c4
If you like easy access to your car's parts and much more top end, the Miniram intake is the key. Contrary to belief, it even works well with a stock cam. TPI and other multi-gasketed intake systems drive me nuts! They are hell to take off and put back on. The only advantage they have over the Miniram is about 50 ft-lbs more torque in the mid range. The Miniram's powerband is like an LT1 and has about a good 700-1000 rpms more on top with a flat and steady torque curve to redline compared to those other ones that drop torque fast past 4000 rpms with long runners.
I'd swap over to some aftermarket heads if I were you.
Old Oct 11, 2006 | 10:38 PM
AKS Racing's Avatar
AKS Racing
I am envious of your coil mount.
Nice install on the MR.
Aaron
Old Oct 11, 2006 | 11:14 PM
kopbet89c4's Avatar
kopbet89c4
2 hose clamps wUrkT 4 mE! You gotta work with what you have!
To Different Intake System
