air coming from everywhere
Old Sep 16, 2001 | 02:05 PM
dt35th's Avatar
dt35th
Default air coming from everywhere
when i have my a/c on air is comming out of defrost vent and heater along with a/c vents. I get some change in air to the different positions, but seems that what ever is diverting the air is not closing all the way.
Does anyone know what controls this.
Old Sep 16, 2001 | 02:10 PM
BobMachus's Avatar
BobMachus
Default Re: air coming from everywhere (dt35th)
vacuum
Old Sep 16, 2001 | 02:17 PM
dt35th's Avatar
dt35th
Default Re: air coming from everywhere (BobMachus)
vacuum
will a vacuum loss cause the doors to not close all the way
Old Sep 16, 2001 | 03:11 PM
BobMachus's Avatar
BobMachus
yes the doors inside the ducting that direct air are vacuum operated. It sounds as if the main line that supplies vacuum to the diverters has come loose, or been crimped or plugged.
***EDIT***
Look around, If you are still confounded, I'll go look at my shop manuals.
Bob
[Modified by BobMachus, 12:13 PM 9/16/2001]
Old Sep 16, 2001 | 03:24 PM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
Sounds like a vacuum problem. I accidently broke the line that runs left rear of the distributor. That caused air to run from everywhere like you said. Carefully inspect the vacuum lines for disconnection or breakage. HTH :flag
Old Sep 16, 2001 | 03:26 PM
War Machine
Forgot to ask if you have the C60 manual or C68 electronic?
Old Sep 16, 2001 | 03:32 PM
Flame Red's Avatar
Flame Red
If it is vacuum, on some years there is a vacuum "T" near the rear of the engine that feeds the AC vent system. These "T"s are prone to disintergrate. Check that first as it is a cheap fix. :D
Flame Red
Old Sep 16, 2001 | 05:54 PM
dt35th's Avatar
dt35th
Default Re: air coming from everywhere (Flame Red)
Thanks for all your replies, I'll check all the vacuum lines :flag
To air coming from everywhere
