SMFW noise
Darrin
i had the fidanza SMFW and it raised royal hell in my '90. oppressive. i had that thing yanked in favor of a brand new DMFW and couldn't be happier with all the positive characteristics it affords for a daily driver. the only positive i ever got from a SMFW was the quicker revs. that was useless compared to all the negatives, and noise was just one of them.
If the noise wasn't a factor, I think more people would agree. I will be switching to the heavier weight castrol 10W-60 oil that zfdoc recommends and see how that does with the noise.
A friend of mine said something about a shroud to go over the tranny to soften the noise?? any suggestions on that?
the previous post did mention the positives, but none of them will help you forget you've got rocks and clanging going on all day.
you made the right decision with getting a new DMFW. you'll be able to sell your Fidanza to someone who wants to use their car for the track. good luck with the changeback, my bet is you'll be glad you did.
oh , -db-, i had the bmw oil you mentioned in mine, didn't help at all. maybe it will help for you, i'll keep my fingers crossed.
2. better off-idle response.
3. better perceived feel of the slingshot effect while winding up in 1rst gr.
4. smoother deceleration.
all in all, a much more enjoyable daily ride. the smfw is relatively lousy choice for the street in a C4. i suspect its more popular for a lightweight import.
Darrin
for you (like me), going back to the dual mass is an upgrade.
when you have it installed, please report back......might as well refer to this thread while you're at it.
Part#52802203
as I said I drive it like an old lady, so I didn't see much need for an upgrade.
You need to use a clutch disk that is listed for use with 93-97 Camaros (Valeo or aftermarket). These will all be sprung hub and all the other dimensions are correct for use with the ZF6. For noise avoidance with the ZF6 transmission, avoid clutch disks that have some of the springs overmolded in plastic or Urethane (McLeod and RAM).
I would recommend changing it sooner rather than later. My friend tried to use a stock solid hub disk with his ZF6, and when he took it out after about 1k miles, you could see the transmission's input shaft splines just begining to wear from the rotational vibration impact.
Mods: 355cid, AFR/TPIS 187cc fully CNC'd 56cc heads, Accel Superram, Accel 219 cam, Speed-Pro forged pistons, Melling lifters, Cloyes double roller chain, stock TB to 52mm by AS&M, CC ProMagnum 1.6 RR's, ARP studs & bolts, FMS 24# injectors, Holley AFPR, Racetronix 255 fuel pump kit, FlowKooler water pump, Hooker #2149 headers & Y pipe, Magnaflow SS catback, Hurst shifter & ball ****, Taylor 8mm wires, CAGS disabled, 180 t-stat, 10.18:1 C/R. Firestone WO's. Tuned by my hero, Alvin at pcmforless
Sounds to me like that car is well on its way to the track my friend. It's just funny to me with all that work done and you don't see the benefits of a SM over a little noise?? Well to each his own. I'm not here to start a problem or throw stones, just making an observation. You car seems like it would surely benefit from the SM. And you could actually here it over that loud exhaust??
I know I can't..except at idle. Nice mods btw Travler, do a little more research on the forum and you will have opinions on both sides. Keep in mind, I DIDN'T go with a fidanza. I went with a nodular iron FW. A little heavier which makes a world of difference. Maybe that's why I don't experience all the negatives others do. Yes there is still noise but thats my ONLY drawback. Have fun
Mr. 6 Speed, Could you tell me for sure if your friend that took it back out after 1k miles had match balanced his new FW?
Sprung hub is a must!
in my earlier post, i listed the cons of the ultra light SMFW. it is for track use, not the street. the benefit of some extra hp unleashed to the wheels is true, although its really not enough to feel SOTP. the quicker revs is kinda neat. the exhaust is loud, but that damn FW was louder still. it was unconscionable, a show stopper, and simply had to get yanked after 6 months.
i do have a strange mentality i suppose, if i could have a daily driver that had 10,000rwhp i'd drive it every day, even just to the grocery store 1 mile down the road, even if thats all i did with it. and i'd still never see the light of day at a track. i guess its just that i don't find the concept of timeslip as a validator.
i call myself "hot rod 90" because it was inspired by a friend of mine whom i respect, pete k.
