eervice engine light
Old Sep 16, 2001 | 07:52 PM
vader86's Avatar
vader86
Default eervice engine light
I have been driving all weekend on the highways and about halfway through my trips the "service engine soon" light has come on. This is during normal operation, highway speed, oil-205-210 and coolant -195F. My trips are about 90mi long and it only comes on on these long trips, not when i just go to the store or something. what could this be?
Old Sep 16, 2001 | 09:27 PM
bogus's Avatar
bogus
Default Re: eervice engine light (vader86)
you must get the codes read. I just don't know how it is done on the 1986s!!
Old Sep 16, 2001 | 10:46 PM
GRX's Avatar
GRX
Do you own a shop manual???
Old Sep 16, 2001 | 11:26 PM
vader86's Avatar
vader86
Default Re: eervice engine light (GRX)
no i dont have one
Old Sep 16, 2001 | 11:33 PM
DADDY D's Avatar
DADDY D
do you have any modifications
Old Sep 16, 2001 | 11:42 PM
vader86's Avatar
vader86
Default Re: eervice engine light (DADDY D)
no mods yet
Old Sep 16, 2001 | 11:53 PM
DADDY D's Avatar
DADDY D
Default Re: eervice engine light (bogus)
do you have a code tester. i know in my 86 my light comes on long trips it normally is a code 32 which deals with the egr. what you need do is get a code scanner and when the light comes on pull over and check it right then and see what comes up.
Old Sep 17, 2001 | 10:06 AM
EU4RIC's Avatar
EU4RIC
I saw a post last week that mentioned this problem. In a nutshell, check the gas cap. A member had check the "codes" and had found nothing and another forum member advised to make sure the gas cap was tight. I have had a similar situation. I can go for weeks w/o seeing the SES and then about 20 minutes into the morning commute it will pop on. However, when I come out in the evening the light is not on when I start up. I have had the codes checked and everything else seems fine. Try the archives and see if you can find the post. :flag
Old Sep 17, 2001 | 10:46 AM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
Default Re: eervice engine light (EU4RIC)
My 86 throws the code 32 on an occasional long trip with like said above is EGR related. You can use a paper clip to jump the a and b terminals on the diagnostic connect under the dash. Do this with the key in run posistion, but the car not started. Watch the SES light, it will flash a code 12- 3 times, then will start with any stored codes in your computer. Codes are read by long flashes followed by shorter ones.
Old Sep 17, 2001 | 12:48 PM
vader86's Avatar
vader86
Default Re: eervice engine light (two-tone86)
how do you fix it if it is a code 32? change a sensor, i'll tighten the gas cap too.
To eervice engine light
