Gas tank bolts...
Old Oct 12, 2006 | 09:09 PM
kopbet89c4's Avatar
kopbet89c4
Default Gas tank bolts...
I see that all the bolts holding the fuel pump assembly are rusty and am starting to get concerned since the car was driven in heavy rain today. Are the bolts holes on the gas tank blind tapped? I'm planning on replacing these bolts soon. What is the correct size of the bolts and their threads? Thanks!
Dom
Old Oct 12, 2006 | 11:03 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
They go straight into the tank. There is an O ring under the bolt shoulder. Can't tell you the pitch and diameter.
Old Oct 13, 2006 | 02:19 PM
CFI-EFI's Avatar
CFI-EFI
If they cause you any trouble, just eliminate them, just like you do everything else.
RACE ON!!!
Old Oct 13, 2006 | 02:31 PM
Wheelman's Avatar
Wheelman
Old Oct 13, 2006 | 03:14 PM
Aardwolf's Avatar
Aardwolf
If the o-rings are ok the rust doesn't matter. From what I remember, mine did not rust, last time I looked. Are most of the bolts on the car stainless?
Old Oct 13, 2006 | 04:46 PM
hippy's Avatar
hippy
RACE ON!!!
1st though he should ask for advice, then disregard it all and do it wrong, (his way.)
Old Oct 13, 2006 | 04:51 PM
CFI-EFI's Avatar
CFI-EFI
I stand corrected.
RACE ON!!!
Old Oct 13, 2006 | 05:32 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
RACE ON!!!
You're incorrigible. Not that that's a bad thing!
Old Oct 13, 2006 | 08:05 PM
LS6 Motor's Avatar
LS6 Motor
Remove the O-rings, and go up to Advance Auto if you have one near you, they have them. I cleaned up all my bolts on a wire wheel, and replaced the O-rings, and gasket, when I did the fuel pump.
Old Oct 13, 2006 | 08:42 PM
RRT vette's Avatar
RRT vette
The bolts are a 10mm head. I bought new o-rings at Napa for $0.35 each. Replace the fuel pump assembly to tank gasket while your at it.
Old Oct 14, 2006 | 04:59 AM
goldeneye_vet's Avatar
goldeneye_vet
RACE ON!!!
Old Oct 14, 2006 | 09:11 AM
DRAKEFAMILY2's Avatar
DRAKEFAMILY2
I did the same thing and got new o-rings at local hardware.
Old Oct 14, 2006 | 09:29 AM
black85vette's Avatar
black85vette
Default tank
You were lucky after soaking the bolts with penetrating oil NOT WD-40
3 of the bolts twisted off flush in the hole!
To Gas tank bolts...
