Smog pump delete? Serp sys. Pics?
Old Oct 13, 2006 | 11:46 PM
Siveck's Avatar
Siveck
How about an F-body alternator and power steering pump bracket along with a grooved pwer steering pulley?
Old Oct 19, 2006 | 07:02 PM
86GoldProject's Avatar
86GoldProject
the vette has a different pump and it wouldn't bolt to the bracket
Old Oct 19, 2006 | 07:55 PM
pablocruise's Avatar
pablocruise
Originally Posted by 86PACER
He re-routed the belt to run over the top of the water pump pulley instead of under it like factory.
Also I think UV mentioned he used a pump that has clock wise rotation allowing the belt to go over the top like that.
Just so it's out there, water pump impellers are directional and need to turn a certain direction. Stock Vette WP's turn counter clock wise.
Good work UV, looks great.
Old Oct 19, 2006 | 10:02 PM
Mtrhd329's Avatar
Mtrhd329
so for this mod a different water pump is required??
Old Oct 20, 2006 | 11:50 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Heres mine on 87:
Old Nov 30, 2006 | 05:37 PM
86GoldProject
bringing this post back from the dead, are there any aftermarket delete pulley's available?
Old Nov 30, 2006 | 06:09 PM
Thrak's Avatar
Thrak
nearly all of them pictured in this thread are aftermarket
Old Nov 30, 2006 | 06:49 PM
86VX1's Avatar
86VX1
hey red rose, can you post more pics of your set-up?
Old Nov 30, 2006 | 07:30 PM
redrose's Avatar
redrose
main bracket, front brace, and cyl head spacer (shown on mule)
side brace and spacer for oem lower alt/ strg pump bracket
rear curved tube brace....fits around smog plumbing (caprice electric smog pump in the back end for emissions)
Old Dec 1, 2006 | 04:27 AM
JoBy's Avatar
JoBy
I changed the water pump and made a tensioner for the alternator.
Old Dec 1, 2006 | 09:50 AM
mseven's Avatar
mseven
Originally Posted by Muffin
Has anyone ever tried to copy one of the aftermarket kits? Sure not rocket science for someone with access to a band saw and lathe. Might cost as much as $20.00. too.
true, plate aluminum, bar stock for pulley spacer, and additional either bar stock center drilled, or allum. tubing, some grade 8 bolts, and a Dayco ribbed pulley. Agent86 made his own and looks great, at one time he had posted a set of plans. The one I bought was a dragon's breath and looks similar, only because I wanted one less thing to work, obviously still need to make a lower support for the alternator as you can see in the pic. was my solution (mild steel tube, and p. coated).
Old Dec 1, 2006 | 12:58 PM
Puna's Avatar
Puna
If you eliminate the smog pump you WON'T pull any codes? What if you block off the egr and remove all the smog cr*p
Old Dec 1, 2006 | 05:49 PM
  #33
garkahn90's Avatar
garkahn90
UV, those are some pretty cool looking plug wire mounting brackets. Did you make or purchase?
Old Dec 1, 2006 | 09:21 PM
  #34
ultraviolet70's Avatar
ultraviolet70
Russel from Summit they look nice but other than that they kinda suck. The plastic retainers the wires pass through are held on by those crappy stamped self tap nuts and there isn't enough post out the back to grab with nuts (might be ok with thinner wire, but they're supposedly rated to hold up to a 9mm and I'm only running a 8.5mm) so I had to drill a bunch of tiny holes and retain them with clips. After getting that figured out found out they interfered with the cast style centerbolt covers so I had to locate spacers, copper washers, and bolts long enough to mount. Sorry run on but just wanted to make sure no else got stuck buying these thinking they're a simple bolt like advertised. Thanks for the compliment though.
