So, my old distributor is pretty worn and with my new 383 going in soon I'm looking at options for ignition. What exactly do I need to buy to put an MSD 6AL box into my car? Is it worth it? I like the programmable rev limiter, which is the main reason I'm considering it. Can I program a rev limit into a 7747 ECM with an ostrich?
Your rev limiter in your 747 is a fuel cut off. The MSD is an ignition interupt. Yes, you can change the fuel cutoff in the ECM. Not sure about the ostrich, I use an autoprom. I would think the ostrich is similar. There is a thread on here about MSDs and the benefits of them. Probably on page 2 now. Quite a debate. My personal (professional) experience is that they work. That is, they do what they say they do. The mutiple spark discharge helps lopey cams idle, engines seem to run a little smoother, and they MAKE POWER (even in mild combos). I'm sure others will chime in and tell me (you) I'm full of hoowey. The programmable rev limiter is nice, but probably the least benificial feature.
Just a point of clarification. The 7747 doesn't have any kind of cutoff. It was a truck ECM and there was no need for one. EBL is custom code using a modded 7747 or other similar ECM. The code has a Fuel cutoff based on RPM or MPH.
I use the Ostrich and it works great for modifying calibrations "on the fly". It is not an emulator. As for the other strengths of the MSD unit,
I agree with edcmat said.
How do you program the EBL? Do you use the ostrich to change the table individually? I guess I'm still a little unsure of exactly what EBL does and how you use it.
Gotcha. We dont do many of those very early ECMs. And dont have any Ostrich exp. If its not an emulator, what is it? Dont need to answer that, dont want to hijack.
An MSD 6AL box is not going to cure your worn out distributor.
I don't deny that they function. Merely, that for the most part, all that they DO provide is not beyond what the stock system gives you, in a mild application. Short version. No ignition system gives more than necessary to do the job. A mild application takes no more than the stock system is capable of giving. Therefore, while the high priced, more powerful, after market system has the ability to provide a hotter spark, it won't, unless the demand becomes greater than the mild engine can place on it.
You tune EBL like any other ECM. There is a .tdf for Tunercat or an .xdf
for TunerPro. You make the changes in the calibration and either burn a new chip or download to the Moates Ostrich. Ostrich emulates a chip.
The benefits of EBL are 1. a more comprehensive code for running modded motors, 2. greater VE and SA table resolution than the 7747 code, and ALDL datastream that puts out 17frames/sec instead of the 1 frames/1.5 sec like the 7747, 3. A Learn capability that can be used to modify VE tables based on either BLM or WB input. If you are already wired for a 7747 or 8746, EBL plugs right into the ECM harness connectors. The 84 Corvette used an ECM with "edge connectors". You can get a "HAM" adapter on www.crossfire.webhop.net to do the conversion for the pin connectors. Bottom line is if you are going to run a modded TBI based motor, this is the ECM to do it with.
Third Gen has a whole thread devoted to tuning with EBL in the DIY Prom Forum.
Here's a screenshot of the Whats Up Display. And this is just the start of it:
The reason I mentioned my distributor was worn out is because I thought the MSD box requires an external coil small cap distributor. If I need a small cap distributor for an MSD box I will buy one to replace my worn distributor so I have to option of an MSD box later.
Dominic,
I think I understand EBL now. It is the same as a regular 7747 ECM, except if samples faster and has larger tables with higher resolution. Does the EBL get soldered into my 7747 or is it an entirely different ECM?
Dominic,
EBL is another board to a 7747 or 8746 ECM. Some others also. You can either send yours to Dynamic EFI or do it yourself and save a couple of bucks. It requires de-soldering one board and soldering the EBL board o a ribbon cable http://www.dynamicefi.com/EBL_Install.html
But rather than a 4k chip, you'll use a 32k.
Once you datalog with EBL, you select Learn VE function in the menu.
It'll ask you for the .bin you datalogged with and then the name for the new .bin you'll be creating. Then you tell it to Playback the datalog. It will then do the calc's for modifying the VE Tables and create the new .bin. You can watch as it makes the changes to the current VE table. Pretty cool. Saves tons of time. The modification of the VE table can be based either on BLM or WBO2 data. Awesome stuff. This does not negate the need to know how to tune. Just makes it faster and easier.
Check out the screenshots:
