Painting engine stuff....?'s
Old Oct 14, 2006 | 12:42 AM
C4boy's Avatar
C4boy
Originally Posted by Bubba91
does anyone have suggestions on removing the valve covers?
No, but have fun replacing those plenum gaskets! [/evil laugh]
Sam, your motor looks cleaner than my dishes. Where do you get the PPG?
Old Oct 14, 2006 | 01:37 AM
Bubba91's Avatar
Bubba91
How hard are they to change?
Old Oct 14, 2006 | 01:46 AM
FF1wms's Avatar
FF1wms
St. Jude Donor '11-'12-'13
Originally Posted by Casethecorvetteman
I would replace the old gaskets while you have it apart yes.
Old Oct 14, 2006 | 02:30 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
This was the old paint job:
Reviesed: Poly chrome coated w/clear (hi temp coating):
Old Oct 14, 2006 | 02:32 AM
C4boy's Avatar
C4boy
I had a PITA time lining up the plenum bolt holes and holding the upper runner gaskets in place, when I did mine.
Best way I found while the lower runner bolts were still attached was - slide the plenum in place between both runners. Then, using a flat head screw driver, lightly pry between the plenum and upper runner, and slip the gasket into place. For slight gasket adjustment, I did the pry trick while one bolt was in place, then tapped the gasket from the bottom to move it up, or vice versa.
Probably a bit easier with the bottom runner bolts loosened.
Old Oct 14, 2006 | 05:11 AM
85C4fanatic's Avatar
85C4fanatic
Just recently did my engine as well. I have a few small details to finish but I powdercoated both the black and red. The black is a 10% crinkle(closest thing I found to match the callaway treatment) and a 120% Transparent red gloss. No clearcoat.Still have to do the master cylendar.
Old Oct 14, 2006 | 08:58 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Simply undo the 4 TORX head screws, remove the PCV and lift them off.
Old Oct 14, 2006 | 10:32 AM
Sam Lam's Avatar
Sam Lam
The Pittsburg Paint & Glass DX 501 product may be obtained from any PPG automobile paint supply house. I think the quart bottle cost about $12 (my memory is going bad ). I am sure there are similiar products that condition aluminum for painting. Agent86 was the one that suggested I use this prior to painting (if I recall correctly). Here is a picture of the bottle and the Rustoleum paint that I used.
Hope this info is helpful to forum members.
Old Oct 14, 2006 | 01:40 PM
Hole-Shot's Avatar
Hole-Shot
If you use the plastic position tabs it make installing the gaskets a breeze. Push in the tabs and those gaskets are not going anywhere.
Old Oct 14, 2006 | 01:53 PM
Bubba91's Avatar
Bubba91
thanks
Old Oct 14, 2006 | 05:49 PM
Bubba91's Avatar
Bubba91
I had to buy some more stuff to do the job. So, it looks like I will have to do it next weekend. I just want to be done with this and a few other things before Turkey Rod Run (next month). I will come back with pics next week.
Thanks for all of the replies and suggestions.
Old Oct 14, 2006 | 05:58 PM
C4boy's Avatar
C4boy
Sam, thanks for the info. I'll look for that PPG or something similar.
The tabs weren't workin for me so I just cut them off. The fit was tight between the plenum and runners since I left the lower bolts attached.
Old Oct 15, 2006 | 04:31 PM
  #33
Zepher's Avatar
Zepher
I did the polished look with the centers of the plenum painted red on my old Bird,
I've got the magnesium vette valve covers to go on my 88 Formula, I need to sand them down and repaint them, probably do a red and black theme.
