Painting engine stuff....?'s
What do I need to buy?
I already have a volt/ohm meter for the TPS. I probably have enough tools.
Any Tricks?
Here is the dist. cover
old used car dealer trick is to spray everything under the hood with clear--everything, no masking or taking things like air cleaners, hoses or belts off....
I'd do clearcoat as well just for that same reason. Its WAY easier to wash and you have less worry about scraping a layer of paint off while washing it.
I need to paint my valve covers, cus my friend, who worked on my 90 L98, at his shop, decided the engine looked a little "dull", actually it just needed a rise-off. Whatever he used (he doesn't know the name, and there's no label on the 10 gallon drum, but "I've used it for years, and never had this happen") did a great job, except, for the valve covers. They turned a lovely shade of copper. Actually, they look kinda nice, but I want them back to stock. The color in your pics look very close to stock. Where did you get it? Is it heat resistant?
I'm thinking of this from Eckler's
http://www.ecklers.com/product.asp?p...&dept%5Fid=122
I'm not sure if it's glossy. Anyone know how it matches the stock color and is it glossy? Or can someone point to product that matches stock color.
My friend mentioned "glass beading " them...that scares me. Anyone done that?
PS: I would clear your stuff for the reasons already mentioned.
1. Removed plenum, runners, valve covers, etc.
2. These parts were glass bead blasted to give a smooth even finish and to remove the oxidation and other crap.
3. Coated parts with a metal prep material called PPG DX501. This coating gives improved paint adhesion to the aluminum and magnesium parts.
4. Buy some Rusteolum Hi Temp Silver paint at Home Depot or Lowe's and spray paint the parts. This is the same paint you would use to paint a BBQ grill.
5. I put a second coat on just to improve the finish.
Here is a picture taken in 2003 after the painting:
Here is another picture taken about a month ago at a car show:
Note that the master cylinder is painted in the second picture and not the first. The exhause heat shield on the drivers side in also painted with Rustoluem Hi Temp Sliver paint.
I did not use clear coat on the parts. Let me know if you have questions on this
I used Eagles though.
I don' Know where to start... uhhh...
Thanks for the replies
Your pics are amazing
I got my gaskets today
I am using valve cover spray that I got from Corvette Central
Here are some before pics...
Then I painted the dist. cover...
I will show the rest when I'm done...
Thanks everyone, but before I go
does anyone have suggestions on removing the valve covers?
