you can get socket heads ( allen wrench) from sears hardware, most other good hardware stores...they are metric, take a sample along with you....imho these should have been socket heads oem
Steel, thanks...Right now the one on the passenger side front is not biting that good and I have a vacuum leak. How much is the stealership charging for the set?|
If you have a vac leak at a bolt location, I'd check the threads in the plenum. They are a softer metal than the bolts and can pull out if over-tourqed. Might be time to do a helicoil.
Yes I know this and was worried the plenum was stripped. Upon further inspection I think the plenum is o.k. The bolt in question has worn threads on the end and does not bite much at all. I used the bolt from the rear on the pass. side and it bites good so I'm hoping I can just get a new set and be done.
Did you get one yet? I have a ton of them from my business: Corvetteplenum.com If you need a couple I will send you out some, No Charge! I'll even pay the shipping! It's the least I can do for all the support I've gotten from the people here on this board.-Mike
