Does oil cooler really do anything?
Old Oct 15, 2006 | 05:51 PM
redrose's Avatar
redrose
it does do something, but not much....based on past work experience with heat exchangers, i can't see that there can be enough ''surface area'' in such a small area as to do much ''exchanging''...maybe enough to reduce warranty cam replacements of flat tappet cams that came with elevated water temps, to meet emission requirements, which lowered oil lubricity....i ran my 86 without the cooler to allow use of the full size oil filter during new engine break-in, effects on oil temp were inconclusive (i did use a clamp-on finned heatsink on the full-sized filter, lost that on the road eventually)
Old Oct 15, 2006 | 09:14 PM
VenkmanP's Avatar
VenkmanP
Originally Posted by Zepher
It's probably from the oil lines weeping or bursting where it goes from metal to rubber. braided AN lines are what I used.
No it's the cooler itself.
Old Oct 15, 2006 | 09:15 PM
Tom 35th anniversary's Avatar
Default Thanks guys!!
Thanks to all for the responses. If the oil gets hotter without it then I will just keep it when I reinstall the motor. Every little bit helps!!!!
