Does oil cooler really do anything?
Old Oct 14, 2006 | 06:08 PM
Tom 35th anniversary's Avatar
Default Does oil cooler really do anything?
I see on my 88 I have the oil cooler between the filter and the block,(at least thats what I think it is). It has a antifreeze line in and out. Does this really do anything in terms of cooling the oil?
Old Oct 14, 2006 | 07:43 PM
bogus's Avatar
bogus
I think it actually does... how much? I donno... but I think it helps a little.
Old Oct 14, 2006 | 08:19 PM
RRT vette's Avatar
RRT vette
Yes, that is your oil cooler. The option in 88 was only $110. It does help some, but only so much.
Old Oct 14, 2006 | 08:55 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
In your a climate, assuming you drive it at least some in cooler weather, one of it's biggest benefits is that a water cooled oil cooler will help bring your oil up to operating temp sooner. Even in warmer weather oil takes a lot longer to get to it's normal operating temp than does the coolant. When your oil warms up faster it minimizes the engine wear, most of which occurs from cold starts and running at less than optimal temps.
Old Oct 14, 2006 | 10:20 PM
Slalom4me's Avatar
Slalom4me
I would be happy to take the OEM oil cooler and its related hardware
off your hands, should you decide to remove it.
Old Oct 14, 2006 | 10:35 PM
JLeatherman's Avatar
JLeatherman
My 84 had a factory oil cooler. The hoses cracked so I bypassed them since I couldn't find replacements. The oil ran more than 25 degrees hotter on a long highway drive. I intend to put a new oil cooler into my car when I reinstall the engine.
Old Oct 14, 2006 | 11:08 PM
Pete K's Avatar
Pete K
Similar increased oil temps on my 87 when I eliminated it. I promptly reinstalled it and they dropped.
Old Oct 14, 2006 | 11:20 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Just so you know,GM dropped the Oil cooler in 92 when the LT1's came out,main reason was they used Mobil One oil,and the breakdown temps were much higher than dino oil.I dont know if the LT1's reversed cooling system made it more diffucult to put one on there anyways,but GM said it was dropped due to synthetic oil.
If youre running Mobil one already,the oil cooler removed shouldnt hurt anything or cause problems.Even if you see a bit higher temps,the better oil wont breakdown like the dino stuff.
However,it cant hurt,speeds up cold weather oil temps and does reduce the oil temps somewhat which may prolong the oils life too.I saw maybe a 10 degree increase/change when I bypassed my oil filter once before on the Vette for a short time,when I owned it.However,I didnt race the car or put it to the test,so cant claim the higher temps others may have seen.
Old Oct 14, 2006 | 11:21 PM
golfpro77's Avatar
golfpro77
I think this was more of an item when temps get high to help reduce oil temps and prolong engine life... read a couple of articles about it and they all say to keep it... I cleaned mine throughly when I rebuilt my 90 - L98. The mechanic that did the machine work on the block said they would not guarantee the engine if I did not have one. They should know best
Old Oct 14, 2006 | 11:22 PM
vader86's Avatar
vader86
Generally they run 10-15F hotter without the cooler in place, in summer.
In winter, it has the opposite effect to help heat up the oil, since the coolant gets up to temp faster than oil.
Old Oct 14, 2006 | 11:31 PM
Aggravated4life
Ya serious? I dropped my engine off at the machine shop and they didnt even know it came with an oil cooler.Its a 350 small block when they get it bare...The oil cooler NOTHING to do with the machine shops engine work.The oil cooler was an OPTION,not a necessity!Not all L98's came with a oil cooler!
Whoever told you that is so full of themselves.Its still a small block chevy...add ons dont make a guarantee of machine work!
Just thought it was nuts to hear that line of BS.
Old Oct 14, 2006 | 11:41 PM
golfpro77's Avatar
golfpro77
I had them diassemble the L98 and put it together as a short block ... they offered a warranty on the assembled short block IF the oil cooler remained on the engine... I know it has nothing to do with machine work ... it does have something to do with the engine warranty as he was offering a complete engine warranty even though I completed the assembly and installed the engine. I believe he used the service bulletin info to require the oil cooler. I think he was just covering his ***. As it was installed from the factory as the option he wanted it installed after the rebuild...I would do the same call it BS if you want but it makes sense if you actually think about it.
Anyway I kept it on after cleaning w/o problems, again not all L98 came with the option but heavy duty cooling I believe was the option which included a larger rad & the oil cooler.
Old Oct 15, 2006 | 08:24 AM
LD85's Avatar
LD85
With it off, my oil was 15-20 degrees hotter, so I am a firm beliver that it does help on my 406
Old Oct 15, 2006 | 08:29 AM
rodj's Avatar
rodj
Ditto here
With local summer temps 85+, oil temp was very close to coolant temp with cooler installed.
Consistantly 25+ higher with cooler disconnected.
Has been reported here previously that cooler can trap particles which are hard to remove completely, care needed when installing on new engines as may dislodge and enter system
Old Oct 15, 2006 | 04:42 PM
Zepher's Avatar
Zepher
My 95 LT1 had a factory oil cooler on it. It was the oil to air style with a small radiator at the front of the car.
Old Oct 15, 2006 | 04:46 PM
Zepher's Avatar
Zepher
DPost
Old Oct 15, 2006 | 04:58 PM
VenkmanP's Avatar
VenkmanP
Assuming you're talking about an F-body - well, duh, this is a vette forum.
If you're talking about a Y-body, you're wrong it was not a factory cooler.
To Does oil cooler really do anything?
Old Oct 15, 2006 | 05:02 PM
Zepher's Avatar
Zepher
Actually, it was a 9C1 B-Body LT1 (police package) that I had put into my 86 Trans Am, but his statement sounds like no LT1's at all came with them.
Old Oct 15, 2006 | 05:14 PM
VenkmanP's Avatar
VenkmanP
This is a C4 forum.
In that context his statement sounds like no C4 LT1s came with them, which is correct.
Also in that context your followup sounds like you have a C4 LT1 with a factory oil cooler, and that's false information.
BTW, you might want to do a little research on that factory oil cooler. If it's the same as the factory F-body LT1 cooler, those guys remove them because quite a few engine failures have been attributed to them.
Old Oct 15, 2006 | 05:23 PM
Zepher's Avatar
Zepher
It's probably from the oil lines weeping or bursting where it goes from metal to rubber. braided AN lines are what I used.
