Cam installation questions??
1) According to the manual, after I remove the roller rockers, rods and valve lifter retainer, I will need to remove the lifters. The manual indicates that some lifters may be difficult to remove and will need some special GM tool to remove the stuck lifters. Should I expect some of the lifters to be stuck, and if so are there any tricks to remove them, or do I need to get this specialized tool?
2) When pulling the cam out, should I twist it back and forth, rotate it clockwise, rotate it counter clockwise or just pull it straigh out?
3) Same question as #2, only when installing new LT4 hot cam.
4) I was told that since I have an LT4, I do not need to replace any lifters or springs. Agreed?
5) When installing the new cam, I need to lube up the lobes with a cam lube, any suggestions on which product?
6) Manual says I should apply motor oil to the Journals of the cam before installation. What are the Journals, and is this a good idea?
7) Should I put any lubricant on the lifters when I replace them and if so, what type?
8) What did I forget? Anything else a novice should be aware of?
Thanks in advance for combined wisdom of the forum.
God Bless America,
Chris Thomas - 1996 LT4
Get a magnetic wand to remove lifters easily.
When installing the cam be careful to not score it on the journals.
The only lube for a roller cam is motor oil.
Mark all parts so they go back where they came from.
1) They shouldn't stick. On flat-tappet cams, sometimes they stick because the bottom of the tappet can get 'mushroom' shaped with excessive wear. That's not a problem with roller lifters.
2) you can rotate it in either direction. Just make sure to pull it straight out or you'll damage the cam bearings. If you screw a couple long bolts into the timing chain bolt holes, it makes a great handle.
3) Same as above -- be very careful of the berings.
4) Correct, unless you have a lot of miles (more than 50K). Inspect everything for wear.
5) Mobil-1. I used 5-30. Also, make sure you clean the new parts (cam, timing chain, etc.) very well with a degreaser, and then oil it up.
6) The journals are the round parts of the cam that sit on the bearings.
7) Yep -- Mobil-1
8) Just keep it all clean! If you didn't get a new timing chain, you should. Mine had 40K miles and the factory timing chain had a lot of slop. I used the GM Extreme-duty LT4 timing chain. Also, I'm assuming you're replacing all of your seals when you reassemble it.
Hope that helps!
as far as installing the hot cam, use mobil one on the journals and don't be shy with it, get them oily!! then use the same technique as used for removal, a slight gentle twisting motion, and go slowly, as the jounals come to each bearing you will have to align them before they go through, take your time don't be hasty, make absolutely sure your lined up before proceeding, its not hard just tedious!! but you can do it!
hope this helps!
chris
Naturally we'll all be here to give you information and help on your project, but there's no substitute for having someone right there with you.
I'm not trying to discourage you - have at it! - I'm only trying to save you an aweful lot of frustration and additional work down the road.
Hope this helps.
Jake
- Clean entire engine, since it is covered with oil/grease.
- Heavy Duty Timing Chain and sprockets
- Head gaskets
- Intake, exhaust, valve cover, oil pan, oil filter assembly and timing cover gaskets.
- Throttle body gasket kit
- optispark
- waterpump
- alternator
- serpentine belt
- several sensors
- Harmonic balancer
lcvette, it looks like you have recently done many of the same mods that I am in the process of performing. I hope you don't mind if I call on some of your experiences as I go along.
Thanks again guys,
Chris - 1996 LT4
I'm right behind all of you on this upgrade path...so I'm glued to these posts. Quick question, if you're doing the head gaskets at this time why don't you have the heads worked on too? You gotta pull them off to replace the gasket, find out how much a machine shop will charge to do a valve job, bowl blend, port match, all that good stuff. Or do we not do these things to LT4 heads?
Another question, can enough of the head be clearanced to lower the compression for a blower or NOS? Or should that be done with the pistons only?
Sam
