Fan Temp Switch trouble
Old Oct 16, 2006 | 03:39 AM
nonetooclose's Avatar
nonetooclose
Default Fan Temp Switch trouble
Help! I cannot seem to locate my fan temp switch on my 1985. Does anyone have a pretty exact location for this switch?
Richard
Old Oct 16, 2006 | 03:53 AM
rodj's Avatar
rodj
One fan or two?
No sure about '85 but later models the ECM controls the main fan and the aux fan in front of the radiator is controlled by a switch in the head
between #1 + 3 spark plugs.
Read http://forums.corvetteforum.com/show....php?t=1518638
for more info.
Old Oct 16, 2006 | 04:46 AM
RRT vette's Avatar
RRT vette
The main fan is controled by the ECM. For the aux fan, I think 85 is a little different that the later L98. It may be on the passenger side where as the 86-89 I know is between #1 and #3 spark plugs.
Old Oct 16, 2006 | 02:35 PM
CFI-EFI's Avatar
CFI-EFI
The ECM controls the main fan. There is a temperature activated fan switch in between the number 6 and 8 spark plugs in the right side head. If you have an auxiliary fan, that switch is what activates it. For 1985, only, if you don't have an aux fan, that switch backs up the ECM control of the main (only) fan. Years after 1985, with no aux fan, don't have a fan switch.
RACE ON!!!
Old Oct 16, 2006 | 04:46 PM
nonetooclose
RACE ON!!!
I do have an aux fan that has never worked. I am a little confused from your description... so does the 85 have a fan temp switch for the main fan? Or is it entirely controlled from the ECM and based on the coolant sensor?
Richard
Old Oct 16, 2006 | 04:52 PM
Wheelman's Avatar
Wheelman
Richard
Completely controlled by the ECM.
Old Oct 16, 2006 | 07:44 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Richard
Does it work when you turn on the air conditioner?
Old Oct 16, 2006 | 08:37 PM
CFI-EFI's Avatar
CFI-EFI
OK. I answered the original question of where the fan switch is located.
I don't understand what part of what I wrote, that YOU don't understand. I thought it was pretty clear. However, you will have to forgive me, English is my first language.
RACE ON!!!
Old Oct 16, 2006 | 09:36 PM
86PACER's Avatar
86PACER
From a past thread on the '85 setup.
Originally Posted by CentralCoaster
Here's a diagram from my 85, also showing where I added the fan overrides.
Old Oct 16, 2006 | 09:42 PM
CFI-EFI's Avatar
CFI-EFI
The red wire and the switch (blue box) were drawn in. They aren't a part of the original schematic. I believe the wire and the switch are for Central Coaster's manual switch.
RACE ON!!!
Old Oct 16, 2006 | 09:48 PM
Z51L83's Avatar
Z51L83
Richard
i think thats only on the 84's, not sure about the TPI cars
Old Oct 17, 2006 | 11:10 PM
nonetooclose
RACE ON!!!
No need to get touchy! Just trying to be clear since it does not make 100% sense yet to me.
In essence I am confused as to where the problem lies... in my ECM or in the switch. The reason there is confusion is because the ECM has malfunctioned in the past (one of the injector power transistors is weak) and I am wondering if it is the cause of the problem, but I want to try the switch first.
Richard
nonetooclose
Unfortunately my AC is dead so I cannot check this...
Old Oct 18, 2006 | 02:23 PM
CFI-EFI's Avatar
CFI-EFI
Richard
What problem? You started this thread with:
That does not indicate a problem or what it might be. I DID answer the question, to which I replied:
In that same post, I explained"
I gave both the with and without auxiliary fan scenarios, because you hadn't stated whether you had an auxiliary fan or not. Than right after that you asked:
Which I had answered and explained before you asked. I'm sorry. I don't get, what you don't get.
Also, I don't get, what you're asking when you say, "In essence I am confused as to where the problem lies...". Me too! you haven't told is what the problem IS.
RACE ON!!!
To Fan Temp Switch trouble
