replacing battery
Old Oct 16, 2006 | 04:04 PM
squalsvette's Avatar
squalsvette
Default replacing battery
Hey Fellas I Just Posted The Message About The Sys Flashing I Was Hoping It Was The Battery...thax For The Quick Response.. You Guys Are Great....next Question What Kind Of Battery Is Best And Whats The Best Way To Take Out....thanx Again Fellas........
Old Oct 16, 2006 | 04:08 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Remove the three screws in the wheelwell. One on top of the panel, and there is a hidden one at the bottom of the panel. For the bottom one, just loosen it enough to slide the panel out. Do not try to bend the panel out of the way, you will break it.
Remove old battery, put new one in, reverse the above steps and you're good.
Replacement choices are many, anything but an AC Delco is your best bet.
I have a NAPA/Exide battery in my '93, it's one of those gel batteries.
I have a NAPA Gold in my '95(in case you were wondering, I have a buddy who own's a NAPA store).
Lots of folks go with the Optima red top.
On my NAPA/Exide, I had to cut off the positive post since GM vehicles use the side posts, the top isn't needed. It needed to be removed to clear the bracket for the ECM.
Old Oct 16, 2006 | 04:12 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
I put a sears diehard in mine last year and no problems at all.
Old Oct 17, 2006 | 01:27 AM
JETSET's Avatar
JETSET
Default battery
in my 87 you take the plastic side panel off with 3 screws in the wheel well one on top and one on bottom. The bottom one only needs to be loosened. Then the batter bolt hold down and it slides out the side.
5 minute job.
Don't take it out the top where you have to remove the cruise etc.
that takes an hour that way and is a pain
I went through a dozen batteries so I can do it in 2 minutes.
they always would balloon or fail from the bumps
I got an Optima red one this time
It is a real nice battery
gel cell
no acid
holds power even when sitting a long time
worth the extra money and they sell them everywhere now
Old Oct 17, 2006 | 05:16 AM
runner140*'s Avatar
runner140*
I live close to a Walmart and purchased the yellow, group 75. $59.00 and guaranteed for three years, no questions asked for full replacement.
Old Oct 17, 2006 | 08:08 AM
LS6 Motor's Avatar
LS6 Motor
AC Delco, but throw it in the lugger after three years. If it is a daily driver, anything mentioned above. I use an AC Delco for ascetics, because I show my car occasionally.
Old Oct 17, 2006 | 10:27 AM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
I have an Optima Red Top in mine. Fits perfectly and has never failed me. Best battery ever!
Old Oct 17, 2006 | 07:00 PM
jon0108's Avatar
jon0108
Default battery
just replaced my acdelco in my 86 with a Interstate megaTron 75. Cant stand the fluorescent green top color but got it for a good price.
Old Oct 17, 2006 | 07:30 PM
zaragoza's Avatar
zaragoza
Veteran: Coast Guard
St. Jude Donor '07 thru '14, '24
I'm running the Optima red top on my 86.
Old Oct 18, 2006 | 11:49 AM
GIJoe's Avatar
GIJoe
Nothing a little spray paint won't fix
Old Oct 18, 2006 | 02:59 PM
Desert1957's Avatar
Desert1957
Default Mega-tron's are awesome
To replacing battery
