'84 Turn Signal Problem
Old Oct 16, 2006 | 05:08 PM
smearig's Avatar
smearig
Default '84 Turn Signal Problem
When I try to signal left the stalk will not click and lock. It will signal if I hold the stalk down, but I want to fix it correctly. Ecklers has 3 parts that look like they might fix the problem, anybody know which one I need?
Cancelling Cam
http://www.ecklers.com/product.asp?p...dept%5Fid=1716
Turn Signal Switch
http://www.ecklers.com/product.asp?p...dept%5Fid=1720
Turn Signal Switch Actuating Cam
Old Oct 16, 2006 | 05:29 PM
Dominic Sorresso's Avatar
Dominic Sorresso
Cancelling Cam
Turn Signal Switch
Are you having a problem with your high beam switch also?
Old Oct 16, 2006 | 05:34 PM
smearig's Avatar
smearig
Nope, the high beams work just fine. I looked at it with a flashlight but nothing is obviously broken.
To '84 Turn Signal Problem
