Changing the water pump
Old Oct 17, 2006 | 01:55 PM
fuzzydawg's Avatar
fuzzydawg
Default Changing the water pump
When I change the water pump on my '94 (AFTER carefully draining the coolant), is there anything I can do to the Optispark to help prevent future problems? Don't want to replace the whole thing, but if there's a way to seal it or vent it or something, that would be a good time, right? Did anybody come out with a better cap, for example, that bolts right on?
Old Oct 17, 2006 | 02:34 PM
F1Fan's Avatar
F1Fan
I believe the GM cap used after '94 is the vented type, that is much less prone to that problem. Search the board for better proof, the opti has been discussed a lot.
Old Oct 17, 2006 | 02:55 PM
pcolt94's Avatar
pcolt94
I dont beleive that there is a vented cap that will just bolt right on. The later vented optis use a different housing. In order to use one, much has to be changed on the front of the engine. Most people I beleive do the mod to vent it.
Even when you drain the coolent, when you remove the pump fluid will come out. Just use rags and try to protect the opti best as possible.
Old Oct 17, 2006 | 03:16 PM
SJW's Avatar
SJW
Consider going ahead and replacing the Opti while you're in there, and going with a DynaSpark as a replacement. There's a lot of benefit to the peace of mind that you'll get when you no longer have to worry about an Opti failure. If you do this, also swap the plug wires, coolant hoses and serpentine belt while you're in there.
Be well,
SJW
To Changing the water pump
