Oil?
Old Oct 18, 2006 | 08:03 AM
frank842's Avatar
frank842
Default Oil?
Just got back from vette show on Sunday. Most vette owners use Mobil 1 synthetic oil. Is this reccomended for all vettes because of the engine temps?
Old Oct 18, 2006 | 08:39 AM
F1Fan's Avatar
F1Fan
I think it is a good synthetic, it is what I use, but there are many others that people like as much/more than Mobile1.
Old Oct 18, 2006 | 09:35 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
When I had my 88 it had a small oil leak at the valve covers. I switched to Mobil 1, oil pressure came up a little bit, but held a steadier lower pressure when warm. That valve cover leak did not increase. If you change to Mobil 1 be prepared to chase down and resolve oil leaks that might spring up. The engine seemed happier with the Mobil 1 over the dino oil. Just an impression, nothing to say it really helped anything other than a steadier oil pressure when hot.
1992 and newer the factory fill is Mobil 1 so I'm sticking with it in my 92.
To Oil?
