87 vette, Trans Overdrive
Old Oct 18, 2006 | 12:12 PM
Mundasi's Avatar
Mundasi
4th Gear
Default 87 vette, Trans Overdrive
I recently purchased a 87 vette with an automatic trans. The vehicle has 105,00 miles on it and it runs, and looks very good. I paid $6400 dollars for it. The car shifts gears fine but I can't tell if the car is going into overdrive. I feel it going into fourth gear but the Overdrive light in the dash does not come on. The question is; do I have a three speed with overdrive or a four speed and the fourth gear is actually the overdrive. At 65-70 miles per hour I am turning in the area of 1900 rpm. I have gotten as high as 25 miles per gallon on the freeway.
Can someone explain to me the characteristics of an 87 vette auto trans?
Thanks, Ric in Suisun California
Old Oct 18, 2006 | 12:26 PM
Aardwolf's Avatar
Aardwolf
Is this 3.07 gear? That RPM sounds right to be in OD. I have never seen an OD light on mine. If you leave it in drive you may see the upshift light. Fourth gear is the OD. Pics?
Old Oct 18, 2006 | 12:29 PM
c4cruiser's Avatar
c4cruiser
If you are looking at the "D" in the square box that is just above the digital RPM display, that is only used for the 4+3 manual transmission cars. It lights up when the manual OD unit is engaged. It should not light up at all in the auto trans cars.
The trans is a 700R4 which has four forward speeds with 4th gear serving as the Overdrive gear. With the console gear selection lever in the D position, that allows the overdrive unit to operate and the 1900 RPM you see at those speeds is correct.
Old Oct 18, 2006 | 07:26 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default overdrive
the trans should shift into 4th at about 42-46 mph, and in that range, the converter locks up, giving the sensation of a shift.
to check the torque converter locking, and unlocking, pick a steady speed, say 55, and put your foot lightly on the brake pedal while still keeping your foot on the gas.
your RPM will increase, then remove your foot from the brake, and the RPM's will drop. They should rise about 250-350 RPM, then with foot off the brake, RPM drops to where it was previously.
The brake light switch controls a solenoid called the torque converter clutch (tcc)
Old Oct 19, 2006 | 03:18 AM
coupeguy2001
Default speed
at 1700 RPM, my 86 is going 75MPH AND I get 31.5 mpg
Old Oct 19, 2006 | 03:33 AM
86PACER's Avatar
86PACER
When mine goes above 30 MPG, my digital cluster just reads 3.0 instead of 30.xx on the average MPG setting and stays there.
Old Oct 19, 2006 | 03:36 AM
86PACER's Avatar
86PACER
The only light you should see is the "Upshift" light on the cluster. There is also an Overdrive light on the warning light display above the stereo, but that one is only used on the manual trans cars. For your car, it will never come on, but it's there.
C4boy's Avatar
C4boy
How the hell are you getting 31 MPG???? I get HALF that!! Please give up the details, man!
Old Oct 19, 2006 | 03:40 AM
86PACER's Avatar
86PACER
Also, to test that the TCC is working cruise at a steady 40MPH then hammer it. If you feel a chugging or lunching feeling for just a second, it's the TCC engaged. Do it again this time with the brake pedal slighly pressed just enough to light up the brake lights. This time there should be no chugging and just smooth instant acceleration when you hammer it. If not, the TCC/Brake light switch needs adjustment.
To 87 vette, Trans Overdrive
