Mobil 1 = Crust free engine???
Old Sep 17, 2001 | 08:45 PM
LWesthaver's Avatar
LWesthaver
Default Mobil 1 = Crust free engine???
Hey guys, has anyone here ever had the intake manifold off of an engine that ran Mobil 1? Did the lifter galley have any oil crust in it? The last engine I rebuilt (20+ years ago) had quite a bit of oil crust in the galley. Is this a thing of the past?
I was just looking into the oil filler hole on my 85 and was suprised to see that the rockers, springs, head etc. is still shiny. Admittedly, I only have 15,000 miles on it but I've never had an engine stay this clean this long.
its very :cool:
Old Sep 17, 2001 | 09:03 PM
KYVette90's Avatar
KYVette90
Default Re: Mobil 1 = Crust free engine??? (LWesthaver)
I use Mobile 1 Trisynthetic and I have very little residue inside my engine, which has 149,000 on it. :cheers:
Old Sep 17, 2001 | 10:06 PM
olephart's Avatar
olephart
Default Re: Mobil 1 = Crust free engine??? (KYVette90)
Yep, you can eat out of most of the Mobil 1 engines. I have been told that the synthetic does not leave as much residue as the dino and that the additive package is superior to most.
Probably some of both. I have a 12 year old 350 truck engine using dino that has 130,000 with 3,000 miles between oil changes. It's almost as clean as a Mobil 1 engine, so I guess you have to really ignore good maintenance to have a really dirty engine.
Old Sep 18, 2001 | 05:09 AM
GlockLT4's Avatar
GlockLT4
Default Re: Mobil 1 = Crust free engine??? (olephart)
A dirty engine looks like this....
I have used Mobil 1 in it ever since I bought it... unfortunately the original owner aparently didn't. The mechanic that owned it right before me used Castrol sythetic.
[Modified by Glock'94, 3:10 AM 9/18/2001]
Old Sep 18, 2001 | 09:21 AM
No Go's Avatar
No Go
I think regular oil changes has most to do with it...Mobil 1 definitely doesn't hurt!
Old Sep 18, 2001 | 11:53 AM
Raysur's Avatar
Raysur
Default Re: Mobil 1 = Crust free engine??? (No Go)
Glock:eek:,
It is clean now?
Mobil 1 has kept my stock motor looking new inside.
Old Sep 18, 2001 | 01:15 PM
vettenuts's Avatar
vettenuts
Default Re: Mobil 1 = Crust free engine??? (Raysur)
I am not sure what was run in mine prior to my purchase at 19K miles, but I haver run either Mobil-1 or Redline since I have had it. I pulled the intake last winter and found a few spots of crust in the lifter valley and was disappointed. But the heads were immaculate.
Old Sep 18, 2001 | 01:24 PM
GlockLT4's Avatar
GlockLT4
I cleaned it as best I could.... I used carb cleaner and got as much of that poopie out as I could without letting anything get down into the lifter valley.
Old Sep 18, 2001 | 01:33 PM
RatRacer's Avatar
RatRacer
Default Re: Mobil 1 = Crust free engine??? (Glock'94)
High ash content is the cause of coke build up. Stay away from Pennsoil and Quaker State if you want a coke free engine
Old Sep 18, 2001 | 02:04 PM
vettes's Avatar
vettes
My heads were off over the summer to fix a head gasket on the 92.Mechanic was commenting on how clean it was in there.It has had Mobil 1 since new.BTW 93K
Old Sep 18, 2001 | 02:06 PM
Z06_BluByU's Avatar
Z06_BluByU
Default Re: Mobil 1 = Crust free engine??? (Cam Potter)
at 123k miles the engine looked like it just rolled off the assembly line when i removed the intake manifold and valve covers.. it has had mobil 1 since birth!!
No knocks or smoking from the motor either.. it runs like the day it rolled off the showroom floor!! I change the oil when the change oil light comes on.. the computer tells you when to change the oil based on temp, milage, RPM and a few other factors... has been working so far
Old Sep 18, 2001 | 02:13 PM
Timmy!'s Avatar
Timmy!
Default Re: Mobil 1 = Crust free engine??? (BluByU)
Here's a pic of my engine that ran Mobil 1 - 98,450 miles =
I couldn't believe the difference!
Old Sep 18, 2001 | 02:28 PM
LWesthaver's Avatar
LWesthaver
Default Re: Mobil 1 = Crust free engine??? (I_HATE_Mustangs)
Wow! I can't see what might be down in the lifter galley, but the top end is immaculate! Amazing for almost 100,000 miles. So, do you attribute this to Mobil 1 or regular oil changes or both???
Old Sep 18, 2001 | 02:51 PM
Timmy!'s Avatar
Timmy!
I think it's the Mobil 1. I changed the oil every 5,000 miles but I don't know about the previous owner. I bought the car with 64,000 on it from a dealer so who knows about it's history, but I'm guessing they had put Mobil 1 in it because despite the torn up main caps and one bad rod bearing, the engine was just spotless!
Old Sep 18, 2001 | 04:46 PM
h rocks's Avatar
h rocks
Glock, everytime I those pictures of you heads, I cringe. I gotta believe it's been caused by more than the brand of oil used. I wonder if that kind of tenacious black varnish is caused by extended dino oil change intervals and blowby. I can only imagine what your exhaust valvestems look like. :U Anyway, you will eliminate it when you do the motor.
Old Sep 18, 2001 | 04:59 PM
88L98's Avatar
88L98
Cruise-In II Veteran
Default Re: Mobil 1 = Crust free engine??? (h rocks)
i just had my intake and valve covers off and ive been using mobil one. it looked just like the one in the picture, it had a couple of tiny pools of mobil 1 sitting on top of the head, but it was still liquid.
Old Sep 18, 2001 | 05:05 PM
h rocks's Avatar
h rocks
Default Re: Mobil 1 = Crust free engine??? (88L98)
Which picture?! I hope it looks like I _Hate_ Mustangs, and not Glocks!
To Mobil 1 = Crust free engine???
