Cruise Control Issues
Old Oct 22, 2006 | 11:40 PM
96BLKLT4's Avatar
96BLKLT4
Default Cruise Control Issues
My cruise doesnt work. It appears as if this car was a highway ride and the CC was used extensively. Anyone have any tips here? I am hoping that it could be something simple (go figure), but I am sure it is more likely the entire arm. Anyone ever replace one of these?
Old Oct 23, 2006 | 01:10 AM
aminnich's Avatar
aminnich
90% of the time it is as simple as a broken vacuum fitting under the passenger side fuel rail cover. Check that first and if not that let us all know and we can go forward from there.
Old Oct 23, 2006 | 01:17 AM
Bad Karma's Avatar
Bad Karma
Here's a link to a thread that addresses this:
http://forums.corvetteforum.com/show...ght=ac+problem
Good diagrams and info inside.
Old Oct 23, 2006 | 08:48 AM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
A while back I had this issue too. Mine was also a simple vac tube that was broken while I was working on it one day and didnt notice I cracked one of those brittle little tubes.
I bought a vac tube kit from AutoZone for a few dollars. It had a couple feet of tubing and lots of little rubber connectors and caps in it to make fit for whatever you needed. I replaced just about everything with one kit.
The car idled better ( found another tube that I broke) and the Cruise worked after that again.
To Cruise Control Issues
